Fork Conversion & Scotts Damper Question..
OLHILLBILLY
Post by OLHILLBILLY »
Now that the fork conversion is done, I'm thinking about the next step.
Are the damper pins (the part that bolts to the steering head) adjustable for height? How do they go about allowing for taller bar clamps? BRP has 3 different heights available for their Scotts compatible clamp it looks. Is it a "1 pin fits all" or do you have to get a different one if you go from the stock height bar clamps to the taller ones? Or is this dealt with in the arm that goes from the damper to the pin?
And how about the added height of the top clamp from the spacer used in the conversion? Is there enough pin height to allow for this with the given bar clamp height?
Trying to get all my info straight now, to prevent buying stuff that won't work later.
Thanks.. Tom
2004 KDX 200.. Coupla mods
2009 KX250F.. Track Star
When I did mine.... I did tons of research and was on the phone with Scotts allot!
I am just glad I got it worked out...
OLHILLBILLY
Ok, I've been thinking of the bolt-on tower set-ups, but they probably work the same way. If not I'll just use the weld on version. Looks like it has the adjustment I was wondering about.
Thanks!
Tom
Yeah Inda, I'll probably be calling them too. KX this, KDX that..
