run 1993 kdx 200 without powervlaves
tydev95
since the center and left power valves on my bike are broken, and i hardly have enough money for a top end and cylinder replate as it is, would the bike run badly if i only ran the right side powervalve?
- Mr. Wibbens
One of mine was busted for years
Sometimes I'd have a good top end and sometimes it would get all blubbery
I believe it was do to the valve vibrating around, sometimes it would be open and sometimes not
Budget_89KDX
I've done a lot of searching and what I've seen a few times are that guys epoxying them into the open position and running them as fixed unit not moving.I too considered this on my 89 since the L subvalve is broke too.but I seen some issues with this the biggest being that the timing in the ignition is curved in sync with the kips.so I don't know how welll it would run.I bought mine and decided to go ahead and not take chances and do it right.maybe look on ebay for a used set but to answer ur question no I wouldn't run just one valve might make tuning a major PITA.
- Mr. Wibbens
Buy spares if you can
- Mr. Wibbens
How much you got?
And does it really need all that?
tydev95
it definitely needs the powervalves, and when i looked into the exhaust port i saw that the intake ports were chipped and there were a bunch of vertical scratches in the cylinder, and there was scratches on the piston skirt. i'm not totally sure about the bottom end, but the flywheel has some up and down play. the bike still starts first or second kick, but i'm not going to run it until i fix it because i dont want to break anything more. and my dad said he'd pay up to $300, and i can probably get about $200 between birthday and christmas money, so i'll have around $500.
- Has thanked: 15 times
- Been thanked: 28 times
I did mine for under 600, but I handled 90% of the labor myself.
Rod kit $90
piston kit (scored a wiseco on ebay for $60)
gasket set $40
cylinder replate $200, maybe more, maybe less. Mine had to be welded.
main bearings and seals $50
transmission bearings $50
The only labor I payed aside from the cylinder was for rebuilding the crank, and that was $60
Seems expensive for an old bike, I know. It was well worth it though. You might do without the crank rebuild, which would save you a bit. If I was gonna tear it all the way down though, I'd go ahead and replace everything I possibly can.
How do you do with sub valves Wibbens? I went through several sets. When I did the rebuild, I used a different cylinder, and made this sort of plate to secure that collar on the RH side that the kips rod slides through. Didn't seem that one set screw was doing it's job over there. That's been quite a while now, and many miles. So far no further problem with the valves.
Rod kit $90
gasket set $40
Not if it's not bad? The play you feel at the flywheel is the main bearings, not the crank. When you pull the cylinder off you will be able to check the condition of the lower rod bearing. That and the connecting rod are the only things that get replaced in a crank rebuild. If they aren't bad, no need to change them.tydev95 wrote:if i didn't get the crank rebuilt, then wouldn't i risk ruining the engine?
However, if the main bearings are shot, it's most likely that the rod bearing is gone as well.
- Mr. Wibbens
I've only been into the cylinder twice in 8 years or so
The first time one valve was missing about 3 teeth, I left it in
6 years later it was broke and had been for quite a long time by the looks of it
After the first top end I do remember having the brass set screw back out on me, allowing the actuator rod to slide out. Sounded like an 80cc bike
I loctited it and never had another issue with it. But I should have made sure the valve was ok
Budget_89KDX
If you got any play in the crank you do run the risk of grenading your motor.I don't suggest running it if you're concerned in any way better safe than sorry.my little brother just brought me his rm250 jug he got back from plating at us chrome and its awesome!total cost to strip and replate was 242.00 round trip.we were going to go sleeved but after reading on here about the plating he went plated then we find out my jug is sleeved on my kdx.but I hope that helps on price and is current.that didn't include any boring bis jug was not bad enough to need bored so they stripped and plated it.as far as labor goes most shops around here are about 60/hr I don't know about other places.
- fuzzy
http://www.langcourt.com is only $180 I believe.
tydev95
here's a couple pictures of the cylinder , head, and piston.
http://s1125.photobucket.com/albums/l58 ... ure011.jpg
http://s1125.photobucket.com/albums/l58 ... ure009.jpg
http://s1125.photobucket.com/albums/l58 ... ure004.jpg
http://s1125.photobucket.com/albums/l58 ... ure008.jpg
- kdxmaniac
can you feel the virtical scraches? it dont look THAT bad from the pics, but cant really tell..... every cylinder i have pulled had some lines in them. if you cant feel them, you can hone the cylinder and youll be fine.
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
gone but not forgotten
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
