Tusk flywheel puller??
The manual states the correct size... your link don't work.
bmiller
I have a puller but it has been so long that I forget what the size is... will it not thread in?
- Been thanked: 19 times
Pretty sure it is reverse threaded!
- skythrasher
bmiller
Hmm... my flywheel doesn't have any threads. It's just pressed on the crank with a key and nut.rbates9 wrote:The flywheel is left hand thread where the puller screws into the flywheel. I just had mine off the other day. The one that I have said that it would fit just about everything.
Maybe I missed something in the manual.....
bmiller
Well,... All of you were right. The LH threads were filled with rust so I couldn't tell there were actually threads there!
Got it all off and attempted to clean it up. Think it'll work?
http://www.phospher.com/index.php/2000_ ... 0:32pm_PST
- skythrasher
- Coop
Careful with paint, it can ONLY go on the outside. I think I would skip the paint and just make sure you used a new gasket and/or a good sealant to minimize water getting in there again. And every few rides is a smart habit to always check bike for loose bolts. I am in the habit of every oil change I go around and check every bolt; fenders, seat, tank, engine, etc. Sort of a "pre-race" check even though I don't race LOL.
2003 KDX200
2003 KDX200
bmiller
bmiller
I was planning on painting the outside and inside but mask off the magnetic surface and center sleeve.Coop wrote:Careful with paint, it can ONLY go on the outside. I think I would skip the paint and just make sure you used a new gasket and/or a good sealant to minimize water getting in there again. And every few rides is a smart habit to always check bike for loose bolts. I am in the habit of every oil change I go around and check every bolt; fenders, seat, tank, engine, etc. Sort of a "pre-race" check even though I don't race LOL.
Bad idea?
I wouldn't paint anything inside....
- skythrasher
I don't see why it would hurt to paint the inside. What reasons are there? I don't even think it would hurt the magnets. Probably wouldn't stick very well. Would be hard to get it clean enough for the paint to stick well without using a solvent or something that could damage the adhesive on the magnets. Do tell why no paint. It had a zinc type coating on it from the factory. And you can't seal it enough to not draw moisture.
bmiller
The cleaning part is quite difficult. As is obvious in the photos, I used a 2HP bench grinder on the wirewheel side to strip the rust off.skythrasher wrote:I don't see why it would hurt to paint the inside. What reasons are there? I don't even think it would hurt the magnets. Probably wouldn't stick very well. Would be hard to get it clean enough for the paint to stick well without using a solvent or something that could damage the adhesive on the magnets. Do tell why no paint. It had a zinc type coating on it from the factory. And you can't seal it enough to not draw moisture.
Tonight, I'm planning on using a small wire brush to clean the inside as well as I can. If I can do it without getting it on the magnets, I'm going to use this:
http://solutions.3m.com/wps/portal/3M/e ... 4L4CH8KYbl
This stuff works magic but is very aggressive.
WHY? Why introduce foreign materials in something that doesn't require it?
Less is more....
Less is more....
