fork swap
stomlinson
fork swap
Post by stomlinson »
i own a 1990 kdx 200 and the fork seals are starting to leak so instead of spending money on the less than desirable stock forks im looking for a set of inverted forks to replace them with. im looking for a complete front end so all that needs to fit is the triple clamps every thing else will come with the front end wheel, brakes etc any information is helpfull thanks. is there a triple clamp that is a direct bolt on?
stomlinson
also i just found 1993 kx 125 triple clamp, and front forks and front brake caliper is this what im looking for or should i be looking for or should i be looking more at 250 kx suspension?
125 is what you want... sprung better for the woods. But, a KX500 front end is a direct swap.... otherwise you would be swapping the stems...
cookycamy101
Post by cookycamy101 »
did the kx500 swap.. premium upgrade
