When i reach top speed in any gear my kdx125 kind of pulls then slows pulls then slows pulls then slows, what could this be?
Also when ever i try to hold a lower rpm in any gear the exhaust just pops loads is that normal?
and last but not least when i release the clutch to slow down it feels like a vibrating feeling between my legs with a wired BURRRRRRRRR noise what cud this be?
oh yes that wasnt the last thing when im going top speed this vibrating is really high, i can feel it through the seat and everything.
any sugestions? what i should check or be looking for? im just learning so any reply would be appriciated. Thanks
top speed jerking?
gregp
I am not familiar with the KDX125, but as far as I know, none of these symptoms are "normal". It sounds like you had better start at square one, and start checking things out.
Some things to check: Tire pressure and condition, chain and sprockets (tension, alignment, wear), air filter cleanliness, carburator cleanliness, clutch assembly (plate thickness, basket condition), power valve assembly and operation, Crank and rod bearings, condition of top end, muffler blockage, etc..
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
- ihatefalling
