KDX SUPERMOTO!!!
lowrider_cutlass
KDX SUPERMOTO!!!
Post by lowrider_cutlass »
hey everyone... i've recently purchased a 2002 KDX220R and have it street plated and have been ripping this thing around like a crazy person... im thinking i most definately want to fully build this bike as a street supermoto... i am going to do the fork conversion to a set of KX250 or KX500 forks, so im wondering if anybody can help me with what size rim and tire combo i need to get, front and rear, what will fit? thanks in advance for any help! i want it to basically be the same as what is on this bike here... http://idisk.mac.com/gerg7836/Public/KDX-SM.JPG
fuzzy
Post by fuzzy »
You will need to have 17" excel rims laced to the KDX hubs, and ideally lower the rear linkage/cut down the forks, and valve both for street use.
heckler
Post by heckler »
headlight? turn signals?
canuckhybrid125
Post by canuckhybrid125 »
How well would a 2stroke work on the street without oil injection system?
It Is What It Is
2000 KX KDX Hybrid
2006 KX 100
2004 TTR 125 LE
2010 KTM 300
Has thanked: 34 times
Been thanked: 59 times
heckler wrote:headlight? turn signals?
He already has the headlight and turn signals are not required in all states.
canuckhybrid125 wrote:How well would a 2stroke work on the street without oil injection system?
Works just fine. I ran Yamaha RD's for years using only premix with no problems. I also use my KDX on the street up to 55mph quite often and have had no issues.
johnyblaze
Post by johnyblaze »
An oil injection system will be a key player in the future of 2T bikes. I love it on the snow machine. Pull in and gas it up. Wish my KDX had it.
1998 KDX220 with goodies
2002 KTM LC4E
2001 Suzuki Bandit 1200S
.... and hope there is oil in the tank and it keeps flowing...
lowrider_cutlass
so how does this work? do i buy any set of excel wheels and have them relaced to my KDX hubs???
Has thanked: 15 times
Been thanked: 28 times
yes. you would lace the rims to your hubs. I saw a supermoto kdx that used wheels off a street bike as well. I don't know what he used...
Ahh, here it is. Thread on dirtflamer.net....
http://www.dirtrider.net/forums3/showth ... =supermoto
fuzzy
Post by fuzzy »
The modern 2T injection (especially concerning 'future') systems are all Direct Injection, and basically work flawlessely. The fuel and oil run off the same pump (different tanks of course) drastically reducing catasrophic events in the case of failure. The carb setups are generally not desired as failure is catastrophic....Gravity fuel, cheezy oil pump.
Full up your tank in 1gal increments, and mark on the outside with a punch or a sharpie/etc. Then when you fill up you'll know how much oil to add FIRST. Carry oil in 1-gal increments (chain saw oil bottles). You can always fill-up, then add oil, but better shake the crap out of it. Also, I'd trust my marks over the pump's guage.
johnyblaze
Sure, that's a way around the issue. It's NOT an issue on snowmobiles. You'd see a lot of riders come back to 2Ts if the oil were injected automatically.
2002 KTM LC4E
Griffbones
Post by Griffbones »
lowrider_cutlass wrote:so how does this work? do i buy any set of excel wheels and have them relaced to my KDX hubs???
Lace them up yourself, it isn't that hard to do. Buy a low cost dial indicator to help true them up. It really is much easier to do than what most people think.
'83 CR60R Fully restored
'97 DR350 (407cc)
2005 KX85 (103.5cc)
2006 KDX 200 (Bone stock other than Jetting, Gnarley woods, Turbine Core II)
2007 250 XC-W (SX head)
Griffbones
juliend wrote:yes. you would lace the rims to your hubs. I saw a supermoto kdx that used wheels off a street bike as well. I don't know what he used...
http://www.dirtflamer.net/forums3/showt ... =supermoto
Wow that motard looks kick AZZ! :supz:
'97 DR350 (407cc)
2005 KX85 (103.5cc)
KdxRiderX
Post by KdxRiderX »
**Edited because I didn't fully read the OP
If it helps, I had wheels built for me from this place: http://www.procycle.us/
Information - RIM 3.5 x 17 dimpled Excel Takasago Signature Series (SKU from Procycle: REWM61736); RIM 4.5 x 17 (SKU REWM91736)
I wanted to have a set of dirt and street (so I went with building custom wheels off of new OEM hubs vs lacing off of my existing hubs) - Excel, Warp 9 also make rims/spoke kits as well.
I'm also in the process of streeting mine for supermoto - I can post back later once I pass the exam and whatnot :)
