Exhaust valve rods in backwards ??
01twostrokingfun
Finished the rebuild but cannot get it to start!! Got a good spark and have gone through the carb jets again but all seems fine. Not starting!!!
The only thing I can think of is I put the exhaust valve rods in backwards and that is preventing it from starting???
I followed the Cyclepedia guide for installation lining up the lines in the middle of the rods with the punch marks on main shaft and the exhaust valve was fully inserted into head.
However, looking at a parts schematic they seem to have it backwards from cyclepedia. Who is right???
01twostrokingfun
HERE ARE THE PICTURES IM REFERRING TO:
IMG]http://i813.photobucket.com/albums/zz53 ... iasite.jpg[/IMG]
01twostrokingfun
This is from cyclepedia site. Is this a pictue of exhaust sub valves with rods of rods and main valve????
>|QBB<[/url]
Getting that in backwards should not stop it from starting however....
01twostrokingfun
Thats the subvalve.... Part number 12005A
01twostrokingfun
HOw do you line it up???? When yoou drop subvalve in you cant see exhaust valve to line it up??
I put it in wrong then....I lined it up on (13107) the main not the sub.
You look in the exhaust port to get lined up....
01twostrokingfun
It's the hole that your exhaust pipe plugs into....
01twostrokingfun
Air, fuel or fire.... it's one of them or a combo of two or all of them.
01twostrokingfun
Both HAVE TO be indexed correctly or it will not function as designed. When closed... the subvalves have to be closed... when engaged fully... the subvalves have to be fully open.
