Magnetic Drain Plugs
- Griffbones
I run magnetic drain plugs in some of my bikes and find that they do seem to pick-up quite a bit of small debris. I don't think I would extend an oil change based on having a magnetic plug, but I do feel they help keep the oil slightly cleaner. They almost look like a Chia pet when you pull them out! LOL
The KDX does not come with a magnetic plug, so I am going to install one at the next oil change. Just curious how many of you choose to run a magnetic plug in your KDX?
'83 CR60R Fully restored
'97 DR350 (407cc)
2005 KX85 (103.5cc)
2006 KDX 200 (Bone stock other than Jetting, Gnarley woods, Turbine Core II)
2007 250 XC-W (SX head)
'97 DR350 (407cc)
2005 KX85 (103.5cc)
akagalford
- Griffbones
Good question, but......
Some clutch plates are steel, transmission gears are steel, etc.......
The bikes that I have installed magnetic drain plugs in, always have stuff on them when I change the oil.
In Inda's words........."Just sayin.............."
'97 DR350 (407cc)
2005 KX85 (103.5cc)
'97 DR350 (407cc)
2005 KX85 (103.5cc)
hockeyboysomers
- Griffbones
Maybe my theory is wrong, but I feel the more particles removed from the oil, the less wear on everything.hockeyboysomers wrote:I use a magnetic drain plug. I figure that it can't hurt.
I like the magnetic plugs and was just curious if others felt there was a true advantage by using them. Either way I am going to continue running them, but I love to get the input and thoughts of fellow riders.
'97 DR350 (407cc)
2005 KX85 (103.5cc)
'97 DR350 (407cc)
2005 KX85 (103.5cc)
- Varmint
- frankenschwinn
Well... it COULD hurt.
Skipro3 had one break off in his pan I believe. The bolt is hollow to facilitate the magnet. Thereby weakening the bolt...
There are different types... so I would want to hold it in my hand before purchasing it ....
bigerestblazer
i run magnetic drain plugs in all my bikes and always have a small coating of metallic crap on them. ive never had one break off but a friend of mine has and bye-bye tranny
either that or the tranny went and took out the bolt? so its kinda a question of if you feel lucky or not
Sometimes in life when it seems like things aint goin your way theres always one answer...BIGGER HAMMER
