Caliper swap question
David_L6
Post by David_L6 »
I have a 2000 KDX 200. I want to install triple clamps and forks from a 2001 KX 500. Will my 2000 KDX caliper work on the 2001 KX forks or do I need to buy the KX caliper?
It should fit fine....
David_L6
Post by David_L6 »
Thank you VERY MUCH for the VERY quick answer.
wbdisco
Post by wbdisco »
I was curious about this also, but I thought I had heard about brake line issues, or is it my imagination?
frankenschwinn
Post by frankenschwinn »
You have to get a little creative with the line routing/clamping to use the KDX brake but it can be done.
This is the bracket I made so that I could use the KDX caliper:
Oh and it looks like you finally made it on here Disco...
wbdisco
Post by wbdisco »
yeah sure did, and I might have some KX250 forks, and triple on the way also
2000 KDX200(mine)
Polini X3(daughter)(FOR SALE)
TRX70(other daughter)
Big Bear 400(wifey)
1969 M35a2 (Deuce and a 1/2)
heckler
Post by heckler »
is that a KDX wheel, axle and brake disc on the KX500 fork?
