Quick coolant question
Alexander220
Post by Alexander220 »
So I'm about halfway through a top end rebuild on an '00 220 and was just wondering how much coolant to fill it with and what kind to use. Also I've heard the 220 has a heating problem and was wondering if anyone could shed some light on that because I am considering removing the airbox lid after the top end which would lean I out (hotter engine). Thanks guys[/i]
Has thanked: 9 times
Been thanked: 17 times
You fill it up until it's full. There's a bleeder on top of the inlet on the head to let trapped air out. There should be another bleeder on top of the LH radiator you can loosen too so the left rad gets filled completely.
You may need to re-jet after removing the airbox lid, unless it's running rich as it is. If you jetted it with the lid on, removing the lid would require you to re-visit those settings.
Alexander220
I've got stock jetting so just remove and I'm good. Oh and what coolant should I run, just any 50/50 mix?
Whatever you like, yep.
KDX4ID
Post by KDX4ID »
CURRENT FLEET
2008 KTM 990 Adventure...Alaska here I come!
2010 KTM 300 XCW... stop me before I buy again!
2005 KDX220... single track sweetie
2007 KTM 450 EXC... my baby
2008 KTM Superduke... Canyon Carver
1996 Honda 650L... GONE but not forgotten
http://www.friendsoftruckeetrails.org
same here
Peak 50/50... never had a boilover....
ihatefalling
Post by ihatefalling »
juliend wrote:You fill it up until it's full. There's a bleeder on top of the inlet on the head to let trapped air out. There should be another bleeder on top of the LH radiator you can loosen too so the left rad gets filled completely.
I wondered what those were for....thanks
2005 KDX 220
R&B Carb Mod
R&B Head Mod
FMF Gnarley
Airbox Mod
Tagged
Alexander220
Alright cool. Have any of you guys tried puttin in a coolant additive like waterwetter or something similar. It might be worth a shot if not
Why for? Unless you are having a overheating problem... it is a big waste of money.
