The last two times I've gone riding, it has been very, very dusty. After the 1st ride in the dust, I cleaned the air filter and greased the rim before installing.
During lunch on my 2nd dusty ride, I went to swap main jets and found a lot of dirt in the bottom of the float bowl cap. My only thought at the time is that I didn't get the air filter seated properly. I checked it and didn't see anything obvious.
Once I got the bike home and cleaned it up, I removed the air box from the bike and was expecting to find a lot of dirt/dust inside the air boot. To my surprise it was clean.
Spending some time doing Google searches led me to some posts of CR 250 owners complaining of something similar. They tracked the problem down to dirt being sucked in through the vent hoses.
Sure enough, that is how dirt got into my carb and engine.
The vent hose that attaches closest to the choke had the most dirt.
I popped it off and stuck a q-tip in there and got this.
Then I stuck the little red straw from the carb cleaner can into that vent and let everything run out into a clean container. This is what came out of that single hose.
So it looks like I'll be buying the little filters that they installed inline on the vent hoses to keep dirt from entering the carb.
Has anyone with an Airstriker carb experienced this? I've never had this problem with any of my other bikes or my other hybrid that used the OEM carb.
