Help needed with Kips
kywoodsrider
I am a long time YZ250 rider, but decided to give the KDX a try. I picked up a like new 2000 KDX220 that the previous owner had put the boysen reeds in, 35mm carb and PC silencer. When I rode the bike for the first time it was completely dead on the top end. I was disappointed. However on the second ride I figured out that the bike was just loaded up. Once I got it cleared out it preformed well. Still a little rich on the jetting. In the process I pulled the slotted access cover off to verify that the Kips was working properly. When I rev the motor the cam turns, but it doesn't turn much at all. The most I could get it to turn while reving the motor was like from the 12 o'clock position to the 11 o'clock. How much should the cam turn?
Looking at that cam is just to verify that it is working.... that's not to say that it is not completely gummed up and needs a cleaning.
Pull the carb and check your jets.... tell us what they are.
kywoodsrider
Correct...
kywoodsrider
It should be fine.... 220 porting is different though.....
I think I would pull the topend and check for a replacement piston (if it's stock you will need to put a Wiseco in) and clean the KIPS assembly.
If you don't have a manual.... get the one up top and to the right. It will guide you through the gotchas of the process. You need to support the actuating arm and the nut on the claw is left hand threaded.
kywoodsrider
Depends on air temp.... it is not one set point.
The point on the piston is that 220 pistons are grenades. They have to be changed out immediately to a Wiseco or you will risk major damage to your bike. It is well documented on this site.
- Rick
kywoodsrider
