I rebuilt the bottom end but did not know wrong piston top end seemed ok so fitted back
Bike ran OK for a mile or so then seized up, striped top end to find piston picked up
Need to re-bore only to find that piston is Honda with steel liner WTF?
(Off a CR250 Marked Prox CR25088 1.50)
Any ideas where I can get a matching piston and as any one heard of this?
According to http://www.serco.com.au the piston I have has a difference in the height from the pin to the crown of 4mm taller from standard type so can only assume that the original owner fitted a shorter con rod?
Thanks for any help john
