Bogging
chriszeee
Bogging
Post by chriszeee »
Having troubles with bogging at WOT. The bike is a 220 completely stock with airbox lid removed at this time. I have cleaned the carb and it idols fine. and seams to run fine when gradually accelerating until the upper rpms hit then it boggs right out, almost feels like the choke is on or its starving for air. While this is happening the exhaust is very smokey. What do you think?
what size jets (main and pilot), what needle do you have? (I assume they are stock)
what altitude are you riding?
If it's all stock, you're probably running too rich, try smaller main.
Also make sure your jets are not plugged up, they may look clean but can be plugged out, use a fine wire to clean them (like a guitar string :wink: )
A good starting point here:
http://www.kdxrider.net/forums/viewtopic.php?t=1156
good luck
chriszeee
Post by chriszeee »
Got it figured out!!!!
Jupiter2
Post by Jupiter2 »
What was the resolution?
gregf@aimcom.com
2000 KDX 200
2002 XR200
Kazuma 90cc quad
chriszeee
Post by chriszeee »
lol the resolve was always check your 11 year old sons work prior to closing things up. The jet came loose.
TWMOODY
Post by TWMOODY »
At least it wasn't the dog ! :lol:
