jetting ?
coffekid
jetting ?
Post by coffekid »
From all the feedback I got from my first question, I decided to put a wiseco piston in my 220 I just bought. I would like to also put boyensen pro reeds in. Do you think the pro reeds are a viable option? Also, will the stock jetting be adequate. It seems like I read the stock 220 jetting was a little fat from the factory, but i'm not sure.
Most bikes are jetted rich off the floor.
'Pro' meaning carbon?
Carbon reeds are generally on the stiff side of things..and that will generally have more effect on the top end of things than the bottom.
That's a lot of 'general' stuff, 'eh? Moto tassinari's carbon reeds have been different in that regard.
..the 220 isn't ever ON the 'top end' of things. It just doesn't get there with the OEM 33mm carb and the port tune it has.
I don't ride a 220...and my input is worth every penny you paid for it...but I'd guess you would be happy with Boyesens power reeds..the fiberglas ones..NOT the carbon reeds.
Save your money for a REAL reed system..like the VF3. :wink:
The jetting your bike requires is pretty much up to you based on your particular bike..your riding style and environs. I doubt the stock jetting is the best choice. The way to find out is to learn how to jet your bike..and do it.
Mr. Wibbens
Re: jetting ?
Post by Mr. Wibbens »
coffekid wrote:From all the feedback I got from my first question, I decided to put a wiseco piston in my 220 I just bought. I would like to also put boyensen pro reeds in. Do you think the pro reeds are a viable option? Also, will the stock jetting be adequate. It seems like I read the stock 220 jetting was a little fat from the factory, but i'm not sure.
Here's a little info for ya
http://www.shopfrpoffroad.com/aboutus.htm
coffekid
jetting?
Post by coffekid »
Thanks Mr.wibbins and you to Carver. Were could I find a jet kit with a good selection of jets at a descent price?
just go to any decent motorcycle shop and get a few size down for the main and pilot (you'll have to know which one you are running), try them and do pug chop test. do a search, you'll find a good post from inda about how to jet your bike
Some shops let you exchange jets. It keeps them from having to buy lots of new ones..and lets YOU try 'some' and trade 'em in for some OTHER 'some'.
If you do happen to trade, look over the jets you pick up to see they aren't damaged, scaped up, plugged up, threads messed up and such.
I got one once that had been overtightened..the threads were fractured at the base of the 'hex' part of the jet.
Has thanked: 9 times
Been thanked: 17 times
Agree with the posts above. A "jet kit" is almost always a waste of some money. You'll end up with plenty of jets you don't need, and only a couple you do. And that's AFTER payin some fool for the service of pickin out which ones he THINKS you need.
Of course, the JD kit is probably worth every penny, since you get those nice custom needles with it....
J.
juliend wrote: Of course, the JD kit is probably worth every penny, since you get those nice custom needles with it....
J.
You may well be right about that! :wink:
