swingarm swapping on H series to E series KDX 200.
Posted: 05:37 am Dec 05 2009
by KDXsg
Hi, anyone knows if the H series swingarm will fit a E series KDX 200?
Posted: 10:32 am Dec 05 2009
by Julien D
well, it'll bolt to the engine, for sure. I'd imagine the frame mounting and shock mounting is different. Any particular reason? I don't think you'd see any benefit over replacing with the correct piece, if it needs replacing.
Posted: 10:53 am Dec 05 2009
by KDXsg
Hi, thanks for the reply. My 1992 KDX swingarm is about 18yrs old and look a bit trashed to date. thought of replacing a 2003 KDX swingarm for her for both looks and ehanced performance.
Posted: 01:06 pm Dec 05 2009
by Julien D
I'm not 100% sure if you can bolt it on or not. I think not without some considerable aggravation. I'm sure someone around here knows for certain!
Posted: 12:38 am Dec 06 2009
by Mr. Wibbens
KDXsg wrote:and ehanced performance.
yeah, I bet you'd gain 3 or maybe 4hp
Posted: 12:49 am Dec 06 2009
by KDXsg
enhanced performance means better handleling in that sense.
Posted: 10:00 pm May 07 2015
by sanstoetter
Sorry to bump this old thread, but my bushings are toast in my 93s swingarm, and I bought a swingarm that was supposed to be from a 94, but it looks like it may be from an h model. I'd rather run it then have to source another E swingarm, but can't find any information whether or not it'll bolt up.
Re: swingarm swapping on H series to E series KDX 200.
Posted: 10:42 pm May 07 2015
by bufftester
It may work, I know the linkages are slightly different between the E and H models. Best bet is to pull your old one off the bike and start taking measurements.
Posted: 10:54 pm May 07 2015
by Gotanubike
I just did swing arm bearings last night on my '90. If you had posted this yesterday I could have taken some measurements
Posted: 11:05 am May 08 2015
by sanstoetter
Bufftester- It looks like I may have to go that route, and just measure/test fit to see if it'll work. I was just hoping that someone else had run across this issue before tearing the bike apart. The current swingarm bushings have so much play that once it's out, and the h series swingarm wont fit, the bike will be out of commission for a few weeks.
Posted: 04:11 pm May 08 2015
by bufftester
They still sell the bushings and bearings for the E-models, that would have been the easier route, but where is the fun in that
Posted: 10:57 am May 22 2015
by sanstoetter
To update... I considered buying bushings/bearings, but the PO painted the original swingarm, and I found E-Series swingarm for $25 shipped with OEM graphics/decent bushings. The H-Series swingarm would probably have worked if I drilled out the links from 10mm to 12mm, but I have no idea how it would would have affected the geometry.
