swingarm swapping on H series to E series KDX 200.
KDXsg
Post by KDXsg »
Hi, anyone knows if the H series swingarm will fit a E series KDX 200?
A true KDX customizer!!
Has thanked: 9 times
Been thanked: 17 times
well, it'll bolt to the engine, for sure. I'd imagine the frame mounting and shock mounting is different. Any particular reason? I don't think you'd see any benefit over replacing with the correct piece, if it needs replacing.
KDXsg
Post by KDXsg »
Hi, thanks for the reply. My 1992 KDX swingarm is about 18yrs old and look a bit trashed to date. thought of replacing a 2003 KDX swingarm for her for both looks and ehanced performance.
I'm not 100% sure if you can bolt it on or not. I think not without some considerable aggravation. I'm sure someone around here knows for certain!
Mr. Wibbens
Post by Mr. Wibbens »
KDXsg wrote:and ehanced performance.
yeah, I bet you'd gain 3 or maybe 4hp
KDXsg
Post by KDXsg »
enhanced performance means better handleling in that sense.
sanstoetter
Post by sanstoetter »
Sorry to bump this old thread, but my bushings are toast in my 93s swingarm, and I bought a swingarm that was supposed to be from a 94, but it looks like it may be from an h model. I'd rather run it then have to source another E swingarm, but can't find any information whether or not it'll bolt up.
Re: swingarm swapping on H series to E series KDX 200.
It may work, I know the linkages are slightly different between the E and H models. Best bet is to pull your old one off the bike and start taking measurements.
Gotanubike
Post by Gotanubike »
I just did swing arm bearings last night on my '90. If you had posted this yesterday I could have taken some measurements :doh: :razz:
1990 KDX200
sanstoetter
Bufftester- It looks like I may have to go that route, and just measure/test fit to see if it'll work. I was just hoping that someone else had run across this issue before tearing the bike apart. The current swingarm bushings have so much play that once it's out, and the h series swingarm wont fit, the bike will be out of commission for a few weeks.
They still sell the bushings and bearings for the E-models, that would have been the easier route, but where is the fun in that :grin:
sanstoetter
To update... I considered buying bushings/bearings, but the PO painted the original swingarm, and I found E-Series swingarm for $25 shipped with OEM graphics/decent bushings. The H-Series swingarm would probably have worked if I drilled out the links from 10mm to 12mm, but I have no idea how it would would have affected the geometry.
