KLX300 fork swap?
- zomby woof
KLX300 fork swap?
I might be able to get a set of KLX 300 forks for the right price.
Has anybody done, or know if this is a do-able swap on a 2000 KDX?
You won't be gaining anything by doing it. Those are basically KDX forks turned upside down. If I am not mistaken.... they still have underhang...
- zomby woof
Thanks. It looks like an easy swap.
You lose the under hang, pick up some rigidity, and gain the proper spring rate at the same time. I have them on my KLX250, and they work a lot better than the KDX fork. I don't know why, but they're not harsh like the KDX forks. I might be able to get them for almost nothing.
If I can, I can't see why I shouldn't do it.
Ontario, Canada
- Has thanked: 15 times
- Been thanked: 27 times
Sure, go ahead. It is a bolt on swap for the entire front end AFAIK. The fact remains that the forks are almost exactly the same as what you have now, except they may look a little cooler ;). If they work better, it is almost certainly a matter of overall condition and tuning rather than anything to do with them being "better" forks.
- zomby woof
I think you're right about condition.
My bike is a 2000, and the previous owner told me he never changed the fork, or shock oil in the 8 years he had it. That might account for some of the nastiness I'm feeling. I think I can get them for less than the cost of a set of springs (and they come with .38 springs), so I should be ahead of the game right there, and yes, they do look cool
- zomby woof
KC-10ENG
Hi Guys,
New to the forum, but need some advice. I own a 2004 KLX 330R not a KDX but the KDX community is doing a lot more fork swaps than the KLX community.
I already have a Stroker Perfomance suspension (Lary Roesler's Company) on my KLX. That kit entails, .75" longer KLX forks and a completely new rear linkage with a KLX shock body with KX 500 internals. it is also 1.75" longer.
Right now I can install the older kX forks, 91-96 KX500 43MM units with my current triples. But if I am going to spend the time and the money what should I install? Any Suggestions??
I also have a 2006 KTM 200XC-W with a Factory Connection set up, but I really like riding my Kawi 4T sometimes. Especially since I installed the big bore kit and pumper carb.
Thanks,
Dennis
Thanks,
Dennis
I don't know for sure. I would assume the steering head is the same as the KDX since the KLX front end is interchangeable with the KDX. I'd look for a complete front end from a kx125/250 or kx500.
You can look around here for some other ideas, pretty much anything that will work on the KDX SHOULD work on your KLX.
KC-10ENG
Ok,
I have done a little more research and the KDX/KLX and KX500 have the same stearing head bearing kit from All Balls. #22-1004. So if you use the 97-2004 KX-500 Triples you can use 46mm forks. That opens you up to all of the newer KX-500 forks, and KX125/250 1996-2001 forks for a swap. With spring rates getting stiffer from 96-2001, .39-.43KG/MM
If I want the newer 48mm forks I believe I would have to change a steering stem. HMM any thoughts from anyone??
Thanks Dennis
Thanks Dennis
- bcdonyo
If your talking about late model KLX250s forks they have less travel. The old 90's kick only dirt KLX250 had the same forks as the 300 with softer springs I believe.99sr220 wrote:Regarding the KLX300 forks? Are these the same as the KLX250 forks? The 250 is considerably heavier bike, so I was wondering if the forks may be too stiff for a KDX?
http://www.planetklx.org/
As far as them being too stiff, I doubt it. KLX300 forks are softer than KDX forks and those on the the early 250 were even softer. If it's a 250s, Japanese DS bikes are usually way undersprung for off roading.
My stock KDX is stiffer than the girl's KLX 300. Both are '05s
- sped66
- Has thanked: 3 times
- Been thanked: 2 times
If I wanted to run an analog odometer that utilizes the stock cable, are the KLX330R forks the only usd option? Just wondering if anything else would work before I start dumping money into my stock forks.
In the stable: '00 KDX220R, '02 XR250R
Gone but not forgotten: '80 XR80, '87 XR200R, '94 KDX250, '01 YZ426F, '86 XR200R
- Been thanked: 19 times
- Mr. Wibbens
http://kdxrider.net/forums/viewtopic.php?t=9504sped66 wrote:If I wanted to run an analog odometer that utilizes the stock cable, are the KLX330R forks the only usd option? Just wondering if anything else would work before I start dumping money into my stock forks.
http://kdxrider.net/forums/viewtopic.php?t=9129
http://kdxrider.net/forums/viewtopic.php?t=9803
- sped66
Thanks Slick Nick. I'm looking for the least expensive way out of the stock forks & like what you did with yours. Keeping my options open for now.
Btw, I caught your "Project KDX 220R - The Rebuild" thread on another forum & found it very interesting.
Mr. Wibbens, thanks for the links... especially the last one. Now I feel like a dumba$$ for not noticing a current topic.
- rbates9
You seem to be pretty proud of those three links.Mr. Wibbens wrote:>|<>QBB<http://kdxrider.net/forums/viewtopic.php?t=9504sped66 wrote:If I wanted to run an analog odometer that utilizes the stock cable, are the KLX330R forks the only usd option? Just wondering if anything else would work before I start dumping money into my stock forks.
- Mr. Wibbens
Some peeps just can't find **** on there own
