Header Pipe Bracket - KDX220
Byte
Post by Byte »
I have learned that my KDX220 does not have a header Pipe Bracket. Should there be one as stock? IF not, what after market part do you recommend I use?
Byte
Has thanked: 9 times
Been thanked: 17 times
I am not familiar with a header pipe bracket...
Should just have 2 springs holding it onto the jug ... and 2 mounts to the frame. Anything more or less is not common.
Byte
Post by Byte »
Cast into jug, I see 2 threaded holes 180 degrees apart more or less that appears like it holds a bracket similar to the one shown in this link...
http://trailtech.net/flange_protector.html
Sorry - the correct terminology is flanger protector.
THoughts?
Byte
You have no springs?
Byte
Post by Byte »
yes 2 x springs.
But also see 2 holes (1 hole each about 1" apart from where the srping hole is).
THese holes are machined and not damaged..
Byte
Don't worry about those....
Byte
Post by Byte »
what are they?
KDX history lesson...
KDX's are distributed all over the world. Other countries KDX's are slightly different. Some use those... yours don't.
