What next?
bezoar
What next?
Post by bezoar »
Have a "new" 2004 200 for recreational purposes. Have read and appreciated this site greatly. Based on info here, I have jetted, replaced front springs with XR springs, boyessen reeds, cleaned and lubed rear bearings, replaced chain and sprockets.
What should be the next maintenance item?
Thanks, enjoy everybody's thoughts!
fuzzy
Post by fuzzy »
Ride and enjoy.
All bearings should be greased...Steering head/etc. Check cond of brake pads.
bezoar
Post by bezoar »
Bearings - greased, Brake pads OK. Riding this weekend!
I am thinking that the radiator probably has never been flushed and this should be done - but not really looking forward to it. Brake fluid has probably also never been changed - but I am not looking forward to that either.
gtoron
Post by gtoron »
Change the oil in the Transmission also.
bezoar
Post by bezoar »
Transmission oil has been changed.
gtoron
Post by gtoron »
Locktite anything that could fall off...ie: nut on kicker
bezoar
Post by bezoar »
I may loctite myself to the seat.
A high output lighting coil....
KarlP
Post by KarlP »
Head cut from RBD? Best $45 a fella could spend on this motor, that's for sure.
MXOldtimer
Post by MXOldtimer »
If you don't know what to do next you must be finished....RIDE!
porterdog
Post by porterdog »
bezoar wrote:I am thinking that the radiator probably has never been flushed and this should be done - but not really looking forward to it. Brake fluid has probably also never been changed - but I am not looking forward to that either.
C'mon- those are both easier jobs by far than cleaning/regreasing the swingarm bearings!
bezoar
Post by bezoar »
Yup, you are probably right. But my last bike did not have a radiator or disk brakes :grin:
porterdog
Post by porterdog »
bezoar wrote:Yup, you are probably right. But my last bike did not have a radiator or disk brakes :grin:
Good on ya then- welcome to the 80's! ;)
Those really are simple jobs- there's a drain screw in the waterpump IIRC (Pull it out, coolant drains. Put it in, system holds coolant again. Magic!) and IMO the best tool for brake bleeding is a big syringe (I get mine from mcmaster.com) and a length of tygon tubing.
