Gear Oil Vent Hose?
nearma12
Gear Oil Vent Hose?
Recently I had a blown water pump seal that was letting coolant into my clutch oil. It was so bad that the coolant was overflowing the gear box after about 1 hour of riding. I noticed my bike (KDX250 '91) was starting to run rough at idle and it was starting to smoke a lot more than normal, so I checked my air filter and it was completely saturated with white milky oil. I had oil all over in the air box, in the bottom, in the intake, I'm sure there was quite a bit that got into the carb. That's when I noticed that there is a hose that vents the gear oil and it ends up inside my air box. I have fixed the water pump seal problem and cleaned the carb, filter, replaced gaskets, and and changed my plug. My question is about the vent hose: Does it need to go inside the air box? Is it some kind of emissions thing or is it pulling a small amount of vacuum from the box? The reason that I ask is in case this ever happens again or if somehow water gets into the gear oil from riding through water all day. It was kind of a pain in the ass to clean all that up from inside the air box, carb, and if it isn't necessary to have it in the air box, I am just going to strap it onto the frame somewhere else. Anybody know? Thanks!
- kdxquebec
