Paging Indawoods
ettev
Paging Indawoods
Yet another question with the KX front swap. I'm using a 2003 KX front rim. What do I do with the KDX odometer? Can it be made to work with the KX rim? If not what goes in its place? A home made spacer? Some other odometer/computer? If an aftermarket odometer/computer which one, and will it be a direct bolt on or is there fabrication involved?
Let's see... your using KX forks... KX rim.... why would you need something to take the place of the KDX Odometer drive gear?
Use the spacers that are on the KX axle.
You will have to use a TrailTech Endurance or Vapor computer if you want an Odometer/Speedometer and it is magnetic pickup driven off the rotor with a magnetic bolt.
