Good aftermarket shifter?
lemmy
When I first got my KDX, I had a hard time shifting up. I noticed the lever was hitting the engine. I took it off and bent it best I could (the damn thing was pretty tough) and it is some better. When riding with tennis shoes, it shifts very easily. But with my cheap Tech3 boots (they are broken in) it shifts great from 1 to 2 and 2 to 3. But it doesn't want to shift up higher than that. So I think it is a combination of it being a bit more difficult to shift and of course the boots. I was wondering if there was a better aftermarket shifter for the KDX that might allow me to shift a bit better. I saw two at motosport.com, but both of them had bad reviews.
september9
I have an IMS lever on my KDX. I like it a lot. Hasn't bent in any of my frequent tip overs yet.
I have heard that the MSR one is junk, but I do not know anybody who has used one personally.
1998 KDX 200
- 2000 KX 125 front end.
- Bills Pipe
- RB Head and Carb !!!
1987 Husqvarna 430XC
- Up-Tite Pipe
- Bills Pipe
- Up-Tite Pipe
The MSR lever has been critiqued as junk. Not IMO.
The problem with that shifter comes about if you don't check it for tight after you first install it. It tightens to 'tight'..and very quickly loosens up as the metal 'gives' some. IF you check it for tight after you ride a bit..and then maybe check it again before the next ride...it will be fine.
I've had mine on for at least a year. I still check it once in awhile, but it's not loosened up after the first check.
lemmy
I have a 2003 KDX220. The only levers I have found is
Moose Steel (MKA1). Moose claims it fits KDX200-220 95-06 and KX80/85/100 86-07
IMS Steel. Even though Motosport claims it will fit my bike, IMS claims it only first 83-01 KDX200/220
MSR Aluminum. Motosport claims it fits my bike. But MSR application chart
http://www.msracing.com/downloads/09MSR ... /chtm1.pdf
claims it will not fit KDX. However it does claim 96-09 KX100. So if it fits that bike and the Moose MKA1 fits that bike and my bike, maybe it would work.
Are there any others?
- skythrasher
I was having problems with shifters and bought a OEM unit from Fredette. Not OEM KDX but from a different model. I believe it was from a early model KD80. He swore to me it would fit and never bend. I have been running it for over a tear now with no problems. The bend in the shifter is slightly different than stock, and seems to cure a weak area. I think the part number may have been 13156-1272 for a 1980 something KD80 but I would not swear to that. A call to Fredette could probably confirm. He said he always ran these on his bikes, and I am very happy also. I don't remember what it cost but it was not any more than an aftermarket.
- Colorado Mike
- skythrasher
Nope don't ridein tennis shoes. I'm in Arkansas, we don't wear no shoes. LOL !
In these parts it is very, very rocky. If you want to keep any shifter here you better move it up. If you don't you'll either lose it or a foot. When you get used to having you shifter moved up the length is not really important anymore. However the length of these KDX and KX80/85 KD 80 shifters id the same I will go take a pic and post it.
Here are the pics.
Here you can see the slight difference in bend. The one I am holding is a OEM KDX shifter the one mounted is from Fredette. It is the one mentioned in the earlier post. They are close enough in length that you can't tell a diff. Sorry about the pic quality I took them with my phone and did not turn the reso up.
Here are the pics.
AtomicKDX
- jc7622
Mt kids ride KTM's as do all of my friends. They all have aluminum shifters and they all have problems with the aluminum splines wearing out. It made made me shy away from buying an aluminum shifter for my hybrid. I have found that the aluminum on KTM's is very soft, though. That could have something to do with it. The aftermarket aluminum shifters may be stronger that the KTM shifters. Still it seems that steel would be more trouble free in the long run.
- barryadam
SVandal
Willbilly
I'm reviving a dead thread!
I have a 2002 kdx 220 with the moose shifter and it becomes loose on the spline the second I touch it. It comes off the spline until the bolt hits the stopping wall on the spline.
This shifter seems like s bad fit but I have a feeling it's something more.
Has anyone else ran into this? What was your solution?
pumpguy
- Been thanked: 2 times
Sounds like there are stripped splines, but where, shaft or lever?
If lever, then it needs to be replaced with something better. If shaft, I guess that's the part that needs replacement. My guess is it's the lever.
As a short term repair, you might try applying Loctite to the shaft before you put the lever on. Be sure to thoroughly clean the shaft and lever splines with Acetone before applying the Loctite and assembling.
Blue Loctite 242 or similar is probably best choice. Red 262 or similar might make removing difficult.
Good luck.
Good luck.
Willbilly
Thanks. The shifter is new. The shaft is suspect but seems okay. Will try your advice w loctite and cleaning and will report back with results after a few rides.pumpguy wrote:Sounds like there are stripped splines, but where, shaft or lever?
Good luck.
september9
It is kind of an older way to do it, but you can adjust how tight the shifter gets by removing some of the material on the inside of where the bolt goes through. Not the hole, but the flat parts that get pressed together when the bolts get tight. Dad used to do it all the time back in the day. It allows the clamp part to get a little tigher/closer together around the shaft.
Not sure if I am explaining that well enough or not though.
1998 KDX 200
- Bills Pipe
- Up-Tite Pipe
- Bills Pipe
- Up-Tite Pipe
Willbilly
I understand you perfectly. That was the first thing I did :(september9 wrote:It is kind of an older way to do it, but you can adjust how tight the shifter gets by removing some of the material on the inside of where the bolt goes through. Not the hole, but the flat parts that get pressed together when the bolts get tight. Dad used to do it all the time back in the day. It allows the clamp part to get a little tigher/closer together around the shaft.
Willbilly
After looking at photos online of the shifter shaft spline I realize that mine is very worn down. I have ordered a new shifter shaft, output bearing, & shift shaft seal (along with a new tire
Will give update when complete.
chippy
Does anyone know more about the OEM shifter Fredette recommended? Part #'s or application?
Willbilly
"Jeff Fredette <sales@frpoffroad.com>chippy wrote:Does anyone know more about the OEM shifter Fredette recommended? Part #'s or application?
Jul 19
to me
we use and sell the shifter from the 1989-1994 kdx's. they don’t bend and hold up very well. we have them for $50.76 in stock."
This item is parts number 13156-1269. The link below is babbit's website.
http://www.kawasakipartshouse.com/oempa ... ange-pedal
I put the new shift shaft on and shifter and it feels great. Race on sunday to test how it works. I also got a 100/100/18 rear tire. It looks like i mounted a front tire on the back, very skinny.
