thanks
David
I curious if the 50 PJ that you've got listed is a typo? The stock 48 PJ that comes in most KDX is bubbling rich at sea level, much less 5,000 to 10,000 feet. My AS was basically useless until I cut the PJ down to a 40 or 42. Now it will semi compensate for the changes thru the day. My throttle response was terrible with a 48 PJ (having a rev profile pipe didn't help things either) but cleaned up a lot when I lowered the PJ and got pretty darn good when I switched to a CGK-3 needle.IdahoCharley wrote:
Bottom line - I'm familiar with the added signal a divider plate will give the low speed circuit and familiar with PJ, AS, needle, MJ changes and their effects. I've just really been impressed with the 38-39 PWK carbs and find the PJ/AS 35 PWK on the 200 not quite upto what I've come to expect from Keihn. I'm happy with the 200's response with a 50PJ AS1.25 CEK3.5 152MJ and slide modified to a little over a 7 cut. (Original cut TV to a 6.5 seemed too rich - had to run a 35 PJ. Cut the TV a little more to better balance the transition between PJ and needle.)
Hi IC;IdahoCharley wrote: The CEK/DEK needle seemed to the recommended needles to use with a 6.5 to 7.0 slide. Cut the original slide to an approximate 6.5 and tried the CEK and had to back the PJ down to a 35. It would still load up some while warming up but clear out quick and once warm and underway it worked fine. I like to run a little larger pilot jet so I modified the slide a second time (actually went further than I should have) and ended up having to run a 50 PJ due to the larger slide cut. Warms-up now and runs very clean and crisp. No need to "clean-out" the engine after a 3-4 minute idle warm-up. If I were to do it over again with a 6.5 slide I should have gotten a DEK needle to install. (I had a CEK along with a couple of other series 13XX needles to try already in the toolbox.)
IC, Call me a stick in mud but its still not clicking for me. How are you verifying that your slide is cut to a 7? Inquiring minds want to know. Your descriptions of it having a harder hit before you recut the slide a second time make it sound like you cut the slide too far (well past 7) and are having to compensate with a overly large PJ. There is a lot of people who run a 7 slide with the RB carb mod and don't run a PJ near that large.IdahoCharley wrote: I ended up jetting the bike close to what people at 1000' level were doing but even with a bigger pilot and we are at 4750' elevation. Of course the pilot may be because my hand cut slide may be closer to a 7.25 or so TV cut. The fuel curve indicates that I'm about 8-10 percent over what Fishead and his friends ended up with when they tested jetting. The bike runs well and I could go safely 1/2 clip leaner on the needle with no problem other than giving up a little torque for the current weather conditions, but a full clip position leads to a very detectable drop off in power.![]()
We really don't have enough miles on the bike to know what it will get for milage but from past experience if you jet for torque output your milage will be better than bikes which have stock jetting adjusted for altitude. Also the spooge factor should not be significant in that you always have fairly good pipe temperature and relatively little condensation of the fuel which does pass through the exhaust system.
I still may try a DEK. Although the DEK may even cause me to have to increase the PJ size upward for the low-end pull.
The first ss with the CEK on the boy's 200 is not a big hit as it is currently set up. Prior to redoing the slide for the second time it was a harder hit - since the engine was fuel rich. That was certainly an indication in my mind that I could improve the throttle response. Don't want my boy to come up to that 8-10 inch log and attempt to loft the front end and instead nail it dead center putting him over the bars!!![]()
One of the important things for the jetting to allow is to be able to predictably loft the front wheel in first and second gear. The KDX seems to be doing that fine and although I haven't hit the official trails with it yet I believe third gear lofting will be possible in the meat of the power band.
