So the ole KDX has been stored in the garage over the winter and i've spent the last week cleaning it up / general maintenance and changed the tires for this year. This afternoon i started it up and went for a short ride. when i got back i noticed the leak in the picture above. I believe it was leaking most of last year too but i contributed it to the build up of an exhaust leak at the flange that i've since corrected.
Whats going on here? is it just the gasket that needs replaced?
While i had the bike apart for cleaning. (i didn't break down the motor) i did a compression check cold and it was 155-160
Also.... i have a habit of changing the oil every ride or every other ride and i began to notice last year that my oil level was slightly lower after a days ride than where i had filled it to.
Am i leaking oil into the KIPS or is this just exhaust spuge??? Or am i paranoid and just need to replace the KIPS gasket.
When i change the gasket can i do it without pulling the motor out. it looks like if i remove all the motor mount bolts and leave the swing arm bolt in i could just rotate it up a bit to get at it.
Thanks,
Sean
