KX triple clamp torque spec
Supposedly from the manual..supposedly for a '99 (46mm forks).
14.5in/lb on the right **edit**wrong...both in ft/lbs
16.3in.lb on the left
Please don't ask why...I have no idea on the left/right part. Neither did the guy that gave me the info.
Suspension Network wrote:Torque the triple clamp bolts to the manufacturer specifications. Remember, the lower triple clamp bolts should not be as tight as the upper bolts.
Has thanked: 153 times
Been thanked: 38 times
inch - pounds?? What are these measurements for, meaning what part / bolt / upper? lower?
My 1994 USD forks have higher torque on the lower than the upper.
If it is triple clamp, then the only think I can think of is brake caliper side causing more twisting torque.
Figures listed were for the triple clamps..top and bottom RH being different from top and bottom LH.
Sorry. I muffed the in/lb part. Wasn't thinking of anything related to forks and or clamps when I wrote it. Indeed it is ft/lbs.
...lot of that going on of late......... :? Apologies.
So both rights are 14.5 and both lefts are 16.5? Maybe that side had the horn and reflectors, too. :grin:
That's pretty interesting that they are different. I don't remember ever hearing of that before.
skipro3
Post by skipro3 »
I torqued mine to the specs given for the stock KDX forks out the manual. I think 14.5 top and 16 bottom, or maybe 18 bottom. In the manual anyway. And that ought to be close enough, since I doubt the factory sent them out torqued correctly.
'Cause you make more left turns on a MX track! :lol:
That's pretty hard to buy CC... Who told ya? Like Ski... I used the specs for the KDX forks... I don't think they are going anywhere.
Buy a manual and let me know what it says... K? :lol:
SeniorKXRider
What I am concerned about is the binding issue if the bottom clamps are too tight. I think the bottom on the 'H' IS 18ft/lb.
Probably not a whole lot to worry about. It's not like getting them too tight by two ft/lbs is going to make your bike 3' taller or anything.... :?
I will use your off kilter specs tonight and see if stiction goes down... doubt it though.... Where'd I put that step stool??? :neutral:
Well... didn't use your scale but torqued to bottoms to 13.5 lbs and the tops to 18. Stiction went down considerably. This is a step in the right direction I believe!
And yes... the bike did drop more... thank GOD! :grin:
