As I stated in my last post, I'll be installing a new Wiseco top end on my 220 in the next couple of days. I also will be installing a set of Boyesen reeds.
Can I reuse the top end gaskets, or should I opt for new ones? Don't really mind spending the $$$, but don't want to if I don't have to. Somebody said I could use some Permatex Copper Sealant on the gaskets with good results. Is this true?
Same goes for the reed block gasket. When I removed it, the gasket stayed stuck to the cylinder, but broke pretty cleanly from the reed block. Does it need to be replaced, or will a *little* RTV or sealant do?
Thanks in advance, guys (and girls). Looking forward to riding my reliable, properly jetted and reeded bike!
________
Suzuki rg250 gamma history
