I have the typical floppy kickstand disease and am wondering if any of you have solved the problem by securing it to frame/swingarm/sidepanel/etc.?
I am thinking of welding on small spring to the end of the kickstand and attaching (hooking) the end of the spring to the hole on the chain/snail adjuster. When riding, it is secured (hooked) to the chain adjuster, and when you need the kickstand simply unhook the spring from chain adjuster. What do ya think? Any other solutions?
Floppy kickstand: Ideas on keeping it secure?
firffighter
crf_kdx
Don't laugh now . . . but I use a cheap (cloth) dog collar that I flip between the swingarm and the rear sprocket just in front of the axle to draw the floppy kickstand into the swingarm. I had to punch a hole in the collar at the appropriate spot so that the kickstand was fairly tight up against the swingarm and I trimmed off the extra length. After replacing the kickstand once with the problem returning . . . I just gave up. I've had no issues with this "fix" over the past 500 miles or so. It's probably only one step above Virginia chrome . . . but then I live in Kentucky. :-)
Cheers!
Cheers!
"There are two kinds of adventurers: those who go truly hoping to find adventure and those who go secretly hoping they won't."
~ William Trogdon
2002 Honda Shadow ACE 750
2005 KDX 200 (mine)
2006 CRF 250X (son's)
2004 TTR 125LE (for sale)
KORHS Series: Senior C
~ William Trogdon
2005 KDX 200 (mine)
KarlP
How 'bout some metal wizard on this site make a decent aluminium stand that will hold to up at least moderate dirtbike use? Make the actual leg replaceable so if you pretzel it, you could fix it.
I'd buy one!
I'd buy one!
- Mr. Wibbens
I just put a new bolt on mine
Works much better
Works much better
My brother and I have always been able to midevally manipulate the stand into working order. It seems the hole get's wallowed out which can be welded up and redrilled. The U mount get's bent out and needs pounded back together. The stop gets worn and needs a good weld put on it. Other than that... no issues keeping the stock stand functioning correctly.
firffighter
The problem with mine is that the frame mount has been worn down below the hole where the bolt goes through. So, it is nice and tight to the U mount on top, but too much slop below the bolt. I managed to wedge a rubber washer in there, but it wont last. I still think a spring cut in 2 then welded to the base of the kickstand so that you could attach the other end to the hole in the chain aduster would work. I think I'll give it a try
