My 00 KTM 380 cylinder was starting to show it age so I sent it off week before Thanksgiving, to US Chrome care of Eric Gorr.
The previous owner had the cylinder intake tracts cleaned and shaped with what was called "trail porting" - leaving a fairly rough surface texture - (no porting timing changes) and had bugged the backside of one of the inlet ports by getting too aggressive with the porting tool - IMHO.
I asked Eric if he would look at this area and weld-up an reshape as necessary prior to having the cylinder replated. (I had run the cylinder this way for 4 years without any problems, but it bothered me every time I performed an R&R and/or R&I on the top end.)
Eric said he would perform an evaluation and heat temper any necessary welds (special procedure for KTMs due to alloys used)
Got back the cylinder Monday and of course took a very good look over everything. The cylinder, porting, and plating look ABSOLUTELY EXCELLENT.
Purpose of this post? For those of you looking for a replate this winter - this is at least the sixth cylinder that I have sent to U.S. Chrome for replating and have been 100% happy with their work. The key may be sending it to them through Eric Gorr. Just thought I would share!
