Hard starting
- Ryan
Hard starting
I cant find my old post but i pulled my bike out of the shed today for the first time. It is about 55 and i have it jetted for 75-80. Anything i can do to get the bike to start easier? Most of the time it takes 50 kicks at least and i am too tired to ride after that. I was thinking to rejet but the bike runs excellent when it starts not too lean and not to rich.
2001 kdx220
1987 honda xl250
1987 honda xl250
BlackStormy
- 2001kdx
Use the choke Ryan...
So wahat are we looking at here?
Bad gas? Old plug? Start at the basics if you haven't already.
Put a richer pilot jet in and try it...
- scheckaet
I would take the carb out, give a real good cleaning to the jets with carb cleaner, replace my plug and change the gas.
Shouldn't be that hard to start. mine is good from 40 to 100F. The only time I had to kick it more than 2 times was around 30-35F.
I'd be suspicious about the gas and carb since you mentioned: "took out of the shed today"...
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- Mr. Wibbens
First thing I'd do is drain the carb, there's a drain on the bottom of the bowl
When this happens to me 90% of the time it is from water/condensation in the fuel
My bike sat for a year and a half, I drained the carb and it started right up with the same old gas in it
Just started my Harley X90 couple days ago. It has been in storage for 4 years. Before storing it I drained the carb. I pulled it out of my shed on Wednesday, gas still smelled ok, started on the seventh kick
If you can't get it to fire within ten kicks I'd say you probably have some water in your gas
it175
IdahoCharley
If your pilot jetting is lean it will be harder to start when cold even with the choke on. (I'm assuming decent gas and no water in carb bowl and a firing spark plug)
1. Lean it over till it pees.
2. Stand the bike back up. Hold the kill switch and kick the engine through 4 times with the choke on.
3. Release the kill switch and kick start the bike.
If it doesn't start within three kicks you must have another problem.
Good Luck!
Good Luck!
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
- Mr. Wibbens
I kinda doubt sitting in the sun had much impact
