CEL Needle No Hit?
- 2001kdx
CEL Needle No Hit?
I threw the CEL in my stock carby and I was expecting a distinctive hit like others have experienced, bit i felt no such thing. I DID feel very good bottom end power, It felt like a power mod right off the bottom. It might have just cleaned up my jetting or something, but I was getting some 3rd gear below-the-kips front wheel lofts. I still however did not feel that famous c taper hit, maybe raising the clip will help? I'm also afraid the DEL, which I also have (thanks to jeb) will be even less noticable.
The needle is only 1 part of the equation...
- m0rie
- 2001kdx
- Jeb
- m0rie
You'll need the next set leaner jet for sure. Buy at 150MJ and 40PJ like jeb suggests as well.
- Jeb
- 2001kdx
As smooth as ever jeb.
Problem is... RICH! This bike SOUNDS rich, I can hear it.
Still pleased with low end torque and performance. I'll hit the dealer up on the weekend for at least the 152/42 combo. I never jetted after installing the REV pipe - I might end up with a BEAST when I throw those jets In!
- scheckaet
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- Jeb
- 2001kdx
I when to my kawi dealer, and they had mains in stock. I bought 152,150 MJ's. I ordered a 42 pilot, but they GOT me. $9.60 for the pilot jet.
Anyway, I put the 152 in, didn't feel that much of a difference. Makes me think the 150 will be spot on. I love the way the bike pulls now, strong off the bottom, and strong through the top. Still pretty smooth too!
I'll also have to fiddle with the clip. I am currently waiting out some white crap covering my woods
- Jeb
- 2001kdx
I'm too much of weenie to hold my bike at max throttle and rpm for more than 5 seconds. I'm only afraid of a huge piston seize or something. It is tattooed on my brain!
On second thought, maybe I'll try it tommorow. I can to 6th gear, be going up a hill so i'm under a load. How many seconds should I go?
- Jeb
If you can get to at least 4th under a load, WOT, 5-6 seconds will probably do it. For a more distinct mark to view, go 10 seconds.2001kdx wrote:I'm too much of weenie to hold my bike at max throttle and rpm for more than 5 seconds. I'm only afraid of a huge piston seize or something. It is tattooed on my brain!
BTW - Do this AFTER the bike is warmed up. Thoroughly warm it up then replace the current plug with a properly gapped plug. Start her up, mosey to where you start your run, make your run. The chop: the throttle closed, clutch pulled in, and motor killed SIMULTANEOUSLY. Coast to a stop, pull the plug and cut the threads away. Don't touch the carbon deposit band and, if you can, take a pic and post it for us. You'll benefit others that will learn how this process works, too!
Another BTW - You don't have to get all the way to 6th; 4th for 10 seconds will be fine. It's not nearly as intimidating (at least for me) to do the chop in 4th rather than at 60-70 MPH!!!
Good luck, you won't regret it
- scheckaet
put the plug in a vise and cut the metalic part (threads) with a hacksaw
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
