Water in the Oil?
4bangr
Water in the Oil?
I was servicing my 200 last night and the crankcase oil looked like it had some water in it. No green like coolant, but water. It had that milky look to it. So, I'm thinking about how the heck it got there. One idea I had is that while power washing, water got past the filler plug. Any other Ideas? Is it possible for coolant to get into the crankcase?
thanks....
thanks....
It's possible but what year is your bike 4bangr? How long has it been since you changed the tranny oil? Condensation is very common also. The best way to check is change the oil and keep an eye on it. You will get to the bottom of it.
4bangr
Condensation is a good idea, something I hadn't thought of. I just bought the bike so it's possible it hasn't been serviced in a while.
Could there be a bad gasket or seal that would allow coolant into the crankcase? I guess this is not a common problem?
I'm glad to find such a good forum, lots of good info here.
It's common in 89 KDX's but beond that.... I don't think so.
- m0rie
The seals for the water pump impeller shaft tend to groove the impeller shaft after a while causing a very slow leak of coolant into the gearbox, just enough to make the oil turn milky. Some of the later E series KDX's and all of the H series came with two oil seals to help prevent this but it still happens. You have to take off the water pump cover and the left side case cover to change the seals out but its pretty straight forward. I would replace the seal(s), bearing and shaft all at the same time. The cost should be around $25-$30 for all the pieces. Good Luck!
-Maurice
-Maurice
- m0rie
If it's a new to you bike...why not take the 'wait and see' attitude 'til next change time? You should be changing the tranny lube every few rides...so it won't be too long to wait. Maybe next oil change it will be fine.
It doesn't take much water to make oil look funny...so you wouldn't necessarily see a drop in coolant level.
cicone
Entirely agree. Have heard it's also possible to "aspirate" water through the overflow hose---riding in deep water and such. Is tranny lube like KY?canyncarvr wrote:If it's a new to you bike...why not take the 'wait and see' attitude 'til next change time? You should be changing the tranny lube every few rides...so it won't be too long to wait. Maybe next oil change it will be fine.
- Has thanked: 50 times
- Been thanked: 17 times
Welcome to the group. What year is your 200? Is your crankcase vent hose routed properly? It sounds like water through the crankcase vent hose or more probable water pump shaft area leakage. You can check http://www.buykawasaki.com and then a place like http://www.ronayers.com. A friend of mine has the same problem on a bike he just bought. We haven't determined the exact cause yet, but are suspecting the crankcase vent hose (routed improperly when he got it) or the water pump seal area. We checked ronayers.com and it was $25 - $30 like morie said.
He is going to use cheap motor oil and change it very often, keeping a close eye on it.
cicone
The prior owner of my bike had that problem once. We never figured it out. Fact was that it sat outside for an extended period--in the rain/high humidity--without being ridden. We guessed it was most likely due to condensation. I change the oil every 2 or 3 rides and have had no problems with it since.
4bangr
The bike is a '93. I bought it for my kid who is 16, just upgrading from a 100cc. I ride a XR600. He was out riding it yesterday, I am so pleased with our decision to buy that bike.
I agree with all you on your assessment; I'm going to wait and watch it before I make a move. One more question though, how much oil does the crank case hold, I thought I read somewhere on here 1Quart. Where should the level be on the site glass? I noticed yesterday that it was spitting out a bit of oil out of the overflow.
- motorider200
The manual says .8 L.
I think the "pour in a whole quart" suggestion is for the 1995 and newer models, but I am not sure.
The manual says to have the level in the middle of the sight glass when the bike is standing up, balanced.
By the way, your 1993 is an "E" model KDX200. The 1989 - 1994 KDX200's are all just about the same. The 1993 and 1994 year did come with upside down forks as a big change. The 1995 - 2005 KDX200's are all very similar, and they are the H models. Some tips will apply to all or some model families, while some tips only apply to a certain model family. Heck, some of my tips don't really apply to any model family.
89kdx200rdr
i run a full quart in my 89. if you have a milky substance on your sight glass change the water pump seal. i have changed mine once. its not common unless u dont do regular maintenance. it's not that hard unless u dont know the difference between a ratchet and a wrench. if u need help holler back.
2003 KX 250
2006 KX 250F
2003 KX 250
2006 KX 250F
