96 Kdx 200
jowens66
96 Kdx 200
I just aquired a 1996 Kdx 200. It has a Pro Circuit Platinum Pipe with a factory sound silencer. I have dropped a tooth on the front sprocket. I was wondering what i can do to make this bike have a ton of low end? Fly wheel weight? R&B Carb and Head? I want it to have four stroke like torque. Whats everyone's suggestion? Thanks
- Mr. Wibbens
FWW, RB head & carb mod & Toulene
- Mr. Wibbens
and get your jetting dialed in, if it isn't
- m0rie
I wouldn't rush out and do this before riding the bike with some of the other suggested mods. You should always play to your strengths and the strength of the 200 mill is its all around power, top to bottom vs the bottom focused power in the 220's. Having the RB head and carb mods done along with proper jetting is going to go a _long_ way towards giving you significantly more bottom end than you currently have. Toss some 607 power reeds or VF3's in there and you'll find that you should be able to get the job done on the bottom and still move it out on top thanks to the rev profile pipe.2001kdx wrote:What wib said, AND switch your pro circuit platinum pipe to a torque type pipe, i.e fmf woods or pro circuit platinum 2.
As an additional aside, all the power and performance in the world don't mean diddle if you don't have a suspension that works right. If you've still got the stock springs in the front and weigh over 135lbs you'll find significantly improved control by swapping out to heavier springs, and removing a couple of shims from the base valve along with an oil change.
jowens66
Also, how much will reeds help? Will they help significantly with the stock carb? How much better are the VF 3's than the boysen reeds in the stock cage? If there is little difference, i would go with the boysen reeds. Moose makes a torque reed spacer, and was wondering if anyone had used this?
The piston is the original, the top end has never been rebuilt and i was wondering if adding a weisco piston would help since it has probably lost compression and such over the years. If i did this, then it would be worth getting the head mod done by R&B?
It seems the carb mod by R&B is the best add on for more power. Correct? Is the stock carb modified as good as the Air Striker Carb?
The fork springs are the stock ones, and i weigh a hair over 200 pounds. I have considered trying to put some KX forks on my bike, but it seems like a lot of trial and error and alot of tools i don't have.
Yes if possible i would like to keep the PC pipe and silencer that is on it if i can get enough bottom end out of the other mods. One more question and i swear ill shut up. Anyone used the FRP Torque Ring?
Sorry for all the questions, but man i love this bike and wanna get it the way i want it so ill have it ready to go in the spring time.
- scheckaet
check thisAlso, how much will reeds help? Will they help significantly with the stock carb? How much better are the VF 3's than the boysen reeds in the stock cage? If there is little difference, i would go with the boysen reeds. Moose makes a torque reed spacer, and was wondering if anyone had used this?
http://www.kdxrider.net/forums/viewtopi ... and+boysen
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
Reed Spacer = no measurable gain
FRP Torque Ring = no measurable gain
Get some .40 springs from Fredette for your forks... rear spring SHOULD be changed to a 5.3 also.....
RB all the way! Modified Air Stryker is better from what i hear but I have a modified stock carb and really don't see how the AS could be better...
Do a compression check on your piston and i wouldn't worry about it til it needs rebuilt. If you get the RB head mod though... go ahead and do the topend also.... the rings should be fresh for the added compression.
- scheckaet
Depends what you call a lot of tools:I have considered trying to put some KX forks on my bike, but it seems like a lot of trial and error and alot of tools i don't have.
I just finished my conversion and the only tools I had to buy were: a torque wrench that I needed anyway, a piece of PVC pipe to change my seals (less than 5 bucks), a wrench for the steering stem nut and that's it!
Lots of trial and error? Nope, not if you read what's on the KX conversion forum and with everybody's help, it's fairly simple and easy.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
You bet on the justkdx forum! You can find hundreds of important things like...oh...uh....the best oil to use!!
THIS has some relevant points of view considering your questions.
'A ton of low end' means different things to different people. If you think you're going to turn the KDX200 into a CR500 or a CRF450..you're not thinking in the right direction.
If you want enough oomph to loop the 200 on a 28º slope even in the slime (wet clay)..that's not too tough.
If you send your carby in, NOT sending your head in at the same time is a waste of time.
Have fun!
Have fun!
