New Pipe Question.
jafo
New Pipe Question.
OK, I got my FMF Gnarly Desert pipe on with the spark arrester tonight. It came with a recomendation sheet on rejeting the carb. Question one is what jetting does a stock '03 220R come with? Two, is the jet change really necessary? I know, these are probabaly stupid questions but hey, you never know.
Oh put my skid plate on too, great fit, nice plate. It's a "Works Connection" aluminum plate, in case someones looking into a skid plate.
Jon.
Jon.
You need a manual jafo!
Pull your jets out and look at em!
- skipro3
Seems every KDX jets a bit different than the last. Like Inda says, check and see what is in your carb right now. Then go do a WOT plug chop check to see if the main is in the ball park. If so, then swap out to the new pipe and run another WOT plug chop and compare plug readings. (If you aren't sure of how to perform a plug chop, say so. No shame in learning how the right way!)
Anyway, that's how I would start out. If you've already got the new pipe on and kept track of how your sparkplugs were looking, then just compare them to see if it looks like the bike is running richer.
Let us know how the new pipe works for you!
jafo
You know if your talking repair manual, I just went through this on my '84, now bought a new bike and need to get another repair manual! Crap! Where does it end!
Yes I would pull the jets out but I'm waiting on getting my reed valve first then pull it all down and back together in one swath. I did'nt know if anyone new offhand what jets come in the bike. Wonder if it's in the owners manual.....Hmmmmm. this the manual your refering to?
You will have to excuse my ignorance right now. I've been working 7 day work weeks for the last three weeks, and getting hit with doubles through the week also with no end in site, so I'm about as sharp as a marble right now.
I need a day off to go riding, unfortunatly it won't be this weekend, suppose to be nice weather.
Jon.
Jon.
Stock jetting depends on the original dealer. Some "Good" dealers jet according to the area. Some "So-So" dealers don't care and give you what the factory sends. http://buykawasaki.com doesn't say?
- Has thanked: 83 times
- Been thanked: 20 times
Congratulations on getting your goodies. Thanks for mentioning the fit of the WC plate.
On the stock jetting, no need for us to parrot what the http://www.buykawasaki.com site says. Your main concern should be the jets that are in your particular carb. No need to focus too much on what is on a spec sheet.
As far as a manual:
SQWAUK, yes you need a manual. Not just the 200 service manual, but the 220 supplement as well!
As far as a manual:
jafo
Doing all sorts of things at once is a recipe for a bad tasting soop. If something isn't right, you won't know where to start. You also won't know what part effected which change.
- fuzzy
Indeed....I'd get the jetting right w/ the new pipe/stock reed cage before you install that DF3. For that matter you should really get jetting sorted out w/ the bike the way it sits--just to see the difference. As Inda said, if your dealer didn't get it close then just a rejet would feel like more of a performance upgrade than the pipe you just bought. However, you can't just let all these new upgrades just sit around...
Go ahead and put the pipe on, then it's time to break out the brass. You'll definitely need some practice w/ the more tolerant stock cage before trying to get things sorted out w/ the new cage...
re: dealers and jet jobs
My first R5 (2-smoke Yamahama twin) had a 'compliments of the dealer' jetting job. They put 90MJs in place of the 130MJ stockers. OK for 5,000'el. Not so good for trips to the coast.
Point is, you need to check your carb for peace of mind...and maybe wholeness of bike!
Fuzzy's right.
Inda's right.
Fuzzy's right.
Inda's right.
GS
jafo
- fuzzy
Sure, that'll be a good start but I'm sure very conservative. Jetting recommendations can't truly be given in a generic fashion due to altitude/temp differences of each owner's locale. You'll get it figured out...Just keep this thread going when you have questions. Carb tuning is the single greatest skill you can teach yourself(mechanically speaking).
Dare I do this?
Guess not one ever had any issues w/ Cdave...
http://justkdx.dirtrider.net/tech_tips.html Lots of good stuff on there, definitely read 'carb tuning' for more information related to this topic...
Dare I do this?
