Cheap reed spacer
Bailey28
Cheap reed spacer
Post by Bailey28 »
The topic of reed blocks and spacers seem hot right now, check out the gallery to see what I made at home on the cheap!! :supz:
FAZ
Mr. Wibbens
Post by Mr. Wibbens »
Be a whole lot easier if you just posted the darn pic :razz:
tim
Post by tim »
Please tells us newbees what diffrence that makes.
06 200H
GALLERY!
RBD
Post by RBD »
NOT a thing ! Dyno says so !
Bailey28
Post by Bailey28 »
It did not make a huge difference, not by any means as huge as installing the RB carb. Thanks again, Ron!
By "difference" on the bottom, it seemed that it got the engine into the powerband slightly quicker and had an even better throttle response. The hit came a little sooner with both the CEK and the DEK needle. DEK still being smoother than the CEK, all clip 4. 40/155
I am running the Boyesen 607 reeds as well. Can't say that it makes any more power by numbers, it just felt a little snappier. I have found the SSS with the air screw before and after this mod.
I can say for sure that I am not the machinist Ron is, as he firsthand saw some of my peanut grinding :shock:
FAZ
