Hmm. OUTCH ! case saver? broken!
kdxquebec
Post by kdxquebec »
The chain master clip went out :shock: The chain went out too :shock: ...
Outch<<<!!
I found my chain in a water hole and I installed my spare master clip :evil: I can not see any leak.
My Idea is to glue the thing with JBWELD and maybe someday get the thing welded....
look :shock: :shock:
IdahoCharley
Post by IdahoCharley »
Outch is right. I really would not worry too much about this - getting it welded and then the hole retapping is likely the best thing to do:
BUT- FWIW - I took the guards off on our bikes since the build-up of mud/combined with brush/weeds,seemed to cause more wear and problems than I thought was associated the chance associated with breaking a chain. On the KDX you can remove the guard and leave the case saver chain deflector if you want to have the best of both worlds.
P.S. I think I remember you getting your finger caught between a chain an sprocket - so YOU may be a "SPECIAL CASE" of needing the guard left in place - :lol: :lol: :lol: :roll: :grin:
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
PLEASE use the case saver!
I had an Indian 175 and removed the guard... chain broke, case busted... lost pieces... end of vintage Indian 175. :evil:
Ever wonder what the damage would have been if it wasn't there? :hmm:
m0rie
Post by m0rie »
I'm with IC, that should be a pretty simple weld. Lots of material and its not a load bearing piece.
kdxquebec
Post by kdxquebec »
yes i think the case saver is important too...Here is the proof :blink:
Idao: thanks to remember me thoses great memories!
:mrgreen:
2001kdx
Post by 2001kdx »
Hey quebec, This just recently happened to me, What did you do with it?
I plan on getting mine JB welded, and having a friend get the bolt out that is stuck inside. Inda's 2 cents kinda made me realize running without is not worth it.
I doubt it'll be strong enough. (vibration, shocks...)
I'm sure there is a way to weld it, that's aluminium right?
2001kdx
Post by 2001kdx »
I'll think it will do just fine, bike should be sold in a matter of weeks. The aluminum weld isn't the problem, the stuck bolt is worse!
post some pics if you can
kdxquebec
Post by kdxquebec »
2001kdx wrote:Hey quebec, This just recently happened to me, What did you do with it?
Nothing is done at this time. :roll:
This is the next point in the "to do list"
1-
2-
3-
4-
5-
6-
7-
8-working on girlfriend bike. (in process)
9-repair my case saver.
10-
11-
12-
Oldschool
Post by Oldschool »
I would fabricate something to attach the case saver to the bolt in front of it ( Face of the fly wheel cover) and forget about blown out one.
Curious...by the term 'case saver' is everyone referring to the same thing? Usually the outer part is the chain/sprocket guard and the INside part is the case saver? I've heard each part referred to differently by lot'sa folks.
Like: 'On the KDX you can remove the guard and leave the case saver..'
..is the way I've thought of the two.
I know some consider the 'guard' to be the 'case saver'.
Which is it?
More tomato tomahtoe?
A good warning KD-Q.. Just last weekend I was looking for my master link clip to keep track of side plate counts. Couldn't find it. It wasn't there!
That's not the first time I've lost a clip. They wear out rubbing on the chain guide. No...it doesn't matter what kind you have, they all do it.
So...CHECK it once in a while. When the clip starts looking wafer-like..replace it!
2001kdx
Post by 2001kdx »
Here is my picture, I had a bit of trouble trying to put it in my reply, so I linked it. You can see the damage here.
*edit* I fixed it.... Indawoods :wink:
2001kdx
Post by 2001kdx »
Successfully done! JB welded, and bolt drilled out. I'll go for a test ride once I get my Brand new Chain/Sprockets/BrakePads/Tire on.
We'll see if JB will hold, KDX-Q
