The reason I bought them is that the previous owner had already swapped out the stem for a klx stem (should be the same as kdx), so I would just have to bolt them on
I have a '98 wheel. I cross-referenced the parts and it appears that axle, axle holders and wheel bearings are the same part number. I hope this means that the wheel will bolt right up. The springs are 0.38 and I weigh 170# without gear, should I look into stiffer springs?
I'm just trying to get a feel for any issues I may be overlooking. Any comments or advice would be greatly appreciated.
Thanks!!!
Tony.
