How does the electrofusion bore impact ring seating (if at all)? Dumb question? The reason I ask it is because the on-line manual makes no mention of removing the glaze like you would in other cylinders leading me to believe that this electrofusion bore is an entirely different beast.
The fast method: I noticed that the mototune article applied to 4-strokes. Different for a two stroke? I've seen enough methods on this site and others that it's becoming hard to distinguish between "slow" and "fast". What YOUR fast method?
Clearance for a Wiseco piston - what should it be? Why should it be more than for a cast piston?
Thanks ahead of time guys! I'm a little extra cautious on this because I have what I think an absolute hunny of a bike and don't want to "blow" it, no pun intended!! So "bare" with me (take it easy if you're reading this Mr. Wibbens sir
