Hi Folks,
Wanted to give some feedback on the new emulsion tube from KDXdazz.
Big improvement with the replacement. The carb on my bike was from Ron Black, new with the divider mod. About 400 hrs currently.
The bike ran well, but smoked a lot, and spooged a lot too. The emulsion tobe was worn about .025mm(.001 inch) oversized.
New part installed, and went to riding place in N California(Stonyford) this weekend past. Much less smoke after operating temp reached, less spooge, and a bit better fuel economy.
1600 - 6000 ft elevation, temps - 60's to 70's.
Thanks Darryl for making these.
Emulsion tube replacement
- Has thanked: 238 times
- Been thanked: 119 times
Re: Emulsion tube replacement
I'm happy to hear of your success with this replacement!
400 hours... That's a new one for me to hear, but considering how much that needle slides up and down and rubs on various areas of the needle jet orifice, I suppose that should not be surprising!
Now you got me worried, as I put almost 500 hours on my current KDX over the past five seasons... With the majority of those running 2 different models of Lectron carbs! Although the way the Lectron works, the metering rod seals almost entirely around the part that could be referred to as the needle jet emulsion tube, and is not prone to moving around causing one spot to take all of the friction as with a tapered needle.
Hopefully the metering rod system lasts a lot longer, but the tube that the rod inserts into is replaceable, fortunately.
I'm fairly certain if I checked my old PWK33 carb's needle jet orifice diameter and it's roundness, it would be quite evident that it is worn out... I took that carb and later that whole bike out of service pending a long planned major rebuild and upgrades, and also have a Ron Black modified PWK35 Air Striker Quad Vent carb which was run on that bike towards the end of its last incarnation.
Thank you for sharing that information with us! Added details like that can really be helpful for those who have the time to share. Much appreciated!
Happy to help Chuck.
Lots of good knowledge on this site. Doing my part to contribute.
We will see how it goes. I don’t get nearly as much riding as you do, so any wear will be drawn out a bit.
I kinda wonder if a bigger diameter needle could be a temporary fix.
Anecdotal story regarding worn tubes -
BMW F650 I had. The emulsion tubes were worn to an oval shape at 50000 miles. New parts improved the fuel economy.
- Has thanked: 30 times
- Been thanked: 95 times
I guess I really need to install the new KDXdazz emulsion tube. I've been reluctant because I'm a little worried about breaking something during the installation process.
Follow up. Some info that might be helpful for folks who want to check their emulsion tube for wear.
The new one measures .115 inch(2.921 mm)
My old one - a .116(2.946 mm) gage pin would go through.
I am using a CEL needle.
I was able to measure using a gage pin, in a pin vise. This combo would fit down where the slide resides.
Hope this is helpful.
