Where did this part come from? Kdx200h
KingDaddyX
Has thanked: 2 times
Post by KingDaddyX »
Also posted in the 200h sub. Sorry and delete if too much, I just want to get back in the woods fast.
I found this washer/shim “tacoed” over behind the clutch cover. Bike is running fine, no noises, maybe 80hrs since I went in there last, even did several hare scrambles.
SpruceItUp
Has thanked: 135 times
Been thanked: 61 times
Re: Where did this part come from? Kdx200h
Post by SpruceItUp »
I don't know about the H series, but on the E series there is a very similar looking washer that goes in between the case and the kick start gear. If it is similar, or even the same, that washer always seems to stick to the inside case but it will fall off very easily.
If I am reading the parts diagram correctly it seems to be the same/a similar setup to the E series for the kickstart mechanism, and there looks to be a washer there.
Here's a photo of the parts diagram, check and see if that washer is there, it may be it.
'92 KDX200
'25 CRF300L Rally
'05 CR125R
kdxdazz
Country: thailand
Been thanked: 41 times
Post by kdxdazz »
I second that, kickstart washer
