What do guys run? I did a search and am seeing 87 mentioned a few times and then 100 a bunch. I don't see the numbers below referenced which is what my manual says.
Standard Oil Level 140 +- 2mm
Adjustable Range 110-170mm
Racetech website tells me to go with the standard 140mm when I input my stats and riding preferences...
stock H series fork oil level
brademan76
- Has thanked: 14 times
- Been thanked: 10 times
- Has thanked: 110 times
- Been thanked: 31 times
Re: stock H series fork oil level
If undecided, one can go low, then add more to adjust bottoming characteristics. Adding oil reduces the amount of air in the fork. More oil equals stiffer final third stroke.
