Rear shock compression adjuster stripped
JZ05220r
Post by JZ05220r »
The flat head adjuster is stripped out on my rear shock. I have a full replacement for it. Also the replacement one came off another shock. I didn’t drill out the peening It just broke loose and came out really smooth anyways. Just wondering if I should use any thread sealer when reinstalling my replacement. Thanks
Has thanked: 110 times
Been thanked: 31 times
Re: Rear shock compression adjuster stripped
Make sure the threads are OK before putting it in.
No thread sealant necessary. Lube the two orings.
JZ05220r
Post by JZ05220r »
KDXGarage wrote: 10:46 pm Jan 30 2023 Make sure the threads are OK before putting it in.
Thank you
JZ05220r
Post by JZ05220r »
One more thing. I can’t find the piston band anywhere. Can I get away without replacing it?
Has thanked: 1 time
Been thanked: 5 times
Piston bands are available from places like SDI, technical touch, etc.
You need the band and the o-ring underneath it, 44 mm. There is just one o-ring. Look up Technical Touch.
JZ05220r
Post by JZ05220r »
KDXGarage wrote: 01:30 pm Jan 31 2023 You need the band and the o-ring underneath it, 44 mm. There is just one o-ring. Look up Technical Touch.
I went on to their site yesterday and punched in both the e series and h series and none were available to each. Should’ve mentioned that earlier. But knowing that it’s a 44mm band is helpful. Just need to know the rest of the dimensions. Thanks
Has thanked: 1 time
JZ05220r wrote: 03:42 pm Jan 31 2023
Don’t worry about what bike a shock was fitted to. Just like KYB 46’s are the same basic fork no matter what bike they came on, so to are the shocks.
JZ05220r
Post by JZ05220r »
Slick_Nick wrote: 06:12 pm Jan 31 2023
Makes sense. Still looking regardless. Thank you.
Would you be interested in a full rebuild kit?
viewtopic.php?f=69&p=223290#p223290
JZ05220r
Post by JZ05220r »
KDXGarage wrote: 04:23 am Feb 02 2023 Would you be interested in a full rebuild kit?
Yes, actually let me make sure my moto sport order cancels then I’ll get back to you. Thanks
Sounds good. Just e-mail me when you are ready. I have all the parts here.
