Turbine core silencer for E model discontinued?
JZ05220r
I can’t find the turbine core anywhere, just the power core.....
JZ05220r
Re: Turbine core silencer for H model discontinued?
JZ05220r wrote: 10:32 pm Nov 06 2022 I can’t find the turbine core anywhere, just the power core..... I’m looking at a universal turbine core but notice it slotted where it would connect the the expansion pipe. Not sure if this would slip over the fmf expansion pipe. Thanks
- Has thanked: 26 times
- Been thanked: 29 times
No, it's not discontinued. It's listed all over the place. RMATV, Motosport, CycleGear, Revzilla, even Amazon and more.
JZ05220r
JZ05220r
Oops I meant the e model lolSS109 wrote: 12:19 am Nov 07 2022 No, it's not discontinued. It's listed all over the place. RMATV, Motosport, CycleGear, Revzilla, even Amazon and more.
Yes, the E-series silencer appears to be discontinued. With that said, the best silencer for the E is the OEM silencer. It's durable, quiet, and easily repackable.
- MoonStomper
- Has thanked: 3 times
- Been thanked: 5 times
Re: Turbine core silencer for E model discontinued?
If you really want a Turbine Core for your E-model, it’s not terribly hard to modify an H model version to fit I would imagine. Some cutting and welding and BOOM!
sarrant
I have an Answer SA Pro-2 for E-Series KDX available. Aluminum silencer with internal turbine core spark arrestor. Lines up and slips on perfectly with FMF pipe. Probably needs a cleanup/repack.
- Has thanked: 110 times
- Been thanked: 31 times
Answer S/A-Pro 2 would be awesome!
Post a FS ad with pics if you can. I would like to see one for an E model. I have a new one for KDX250. I have never used one, but it looks awesome. I have the first version on my 87.
JZ05220r
I’m interested. The silencer that came on my e model has answer etched in it ironically but it’s riveted so I can’t repack it and a bit beat up. If you could share a few pics I’d appreciate itsarrant wrote: 03:52 pm Nov 08 2022 I have an Answer SA Pro-2 for E-Series KDX available. Aluminum silencer with internal turbine core spark arrestor. Lines up and slips on perfectly with FMF pipe. Probably needs a cleanup/repack.
sarrant
I will try to fish it out and get a pic, but are you sure the Answer silencer is riveted on both ends? Usually it is only one. Also, you can drill the rivet out and replace with a sheet metal screw upon reassembly.
JZ05220r
I will double check that tomorrow. Thanks for that tip with the sheet metal screw. It is definitely too beat up for my build and the look I’m going for.sarrant wrote: 07:28 pm Nov 08 2022 I will try to fish it out and get a pic, but are you sure the Answer silencer is riveted on both ends? Usually it is only one. Also, you can drill the rivet out and replace with a sheet metal screw upon reassembly.
JZ05220r
Thank and I will double check. Thanks for the tip with the sheet metal screws. It is too beat up for the fresh look I am going for though.sarrant wrote: 07:28 pm Nov 08 2022 I will try to fish it out and get a pic, but are you sure the Answer silencer is riveted on both ends? Usually it is only one. Also, you can drill the rivet out and replace with a sheet metal screw upon reassembly.
sarrant
Not sure that this is a restoration quality piece either, but it is a nice forest service approved arrestor that is exact fit for E-Series KDX and should clean up and repack nicely.
I recall it as being very quiet, especially for aftermarket.
JZ05220r
How much money would you like for that. I think maybe I could have it cleaned and polished. Thankssarrant wrote: 05:57 pm Nov 09 2022 Not sure that this is a restoration quality piece either, but it is a nice forest service approved arrestor that is exact fit for E-Series KDX and should clean up and repack nicely.
I recall it as being very quiet.
JZ05220r
Thanks for the pics. I can see that looking pretty nice if I cleaned it real good and painted it black. I’ll consider it. How much would you like for it? Thank yousarrant wrote: 05:57 pm Nov 09 2022 Not sure that this is a restoration quality piece either, but it is a nice forest service approved arrestor that is exact fit for E-Series KDX and should clean up and repack nicely.
That would clean up fairly easy.
sarrant
How about 50 + shippingJZ05220r wrote: 06:25 pm Nov 09 2022How much money would you like for that. I think maybe I could have it cleaned and polished. Thankssarrant wrote: 05:57 pm Nov 09 2022 Not sure that this is a restoration quality piece either, but it is a nice forest service approved arrestor that is exact fit for E-Series KDX and should clean up and repack nicely.
Please take the wheeling and dealing to PM, email, or phone/text. If you need me to pass on contact info to each other please let me know and I'll be happy to do it. Thank you.
sarrant
