1986 KDX80 shift lever?
Jonnylightening
Anyone know of an aftermarket shifter or the size of the shift shaft on a kdx80? I just bought one from pro taper that was supposed to be an exact fit but definitely wasnt
- ss109
- Has thanked: 33 times
- Been thanked: 55 times
Re: 1986 KDX80 shift lever?
Those bikes aren't that common, sadly, so finding info is kind of tough. Best bet is to pull the old one off and measure the shaft. That will give you an idea of what might possibly work.
- Has thanked: 191 times
Here's which models came with that shift shaft. See if you can fine a lever for an old KX60.
This Kawasaki 13161-1108 LEVER-COMP-CHANGE SHAFT fits the following models and components:
Kawasaki Motorcycle 1995 KX60 - KX60-B11 Gear Change Mechanism
Kawasaki Motorcycle 1994 KX60 - KX60-B10 Gear Change Mechanism
Kawasaki Motorcycle 1991 KX60 - KX60-B7 Gear Change Mechanism
Kawasaki Motorcycle 1987 KDX80 - KDX80-C4 Gear Change Mechanism
Kawasaki Motorcycle 1986 KDX80 - KDX80-C3 Gear Change Mechanism
Kawasaki Motorcycle 1985 KX60 - KX60-B1 Gear Change Mechanism
Kawasaki Motorcycle 1996 KX60 - KX60-B12 Gear Change Mechanism
Kawasaki Motorcycle 1984 KX60 - KX60-A2 Gear Change Mechanism
Kawasaki Motorcycle 1990 KX60 - KX60-B6 Gear Change Mechanism
Kawasaki Motorcycle 1986 KX60 - KX60-B2 Gear Change Mechanism
Kawasaki Motorcycle 1983 KX80 - KX80-E1 Gear Change Mechanism
Kawasaki Motorcycle 1988 KX60 - KX60-B4 Gear Change Mechanism
Kawasaki Motorcycle 1988 KDX80 - KDX80-C5 Gear Change Mechanism
Kawasaki Motorcycle 1987 KX60 - KX60-B3 Gear Change Mechanism
Kawasaki Motorcycle 1985 KDX80 - KDX80-C2 Gear Change Mechanism
Kawasaki Motorcycle 1984 KDX80 - KDX80-C1 Gear Change Mechanism
Kawasaki Motorcycle 1983 KX60 - KX60-A1 Gear Change Mechanism
Kawasaki Motorcycle 1983 KDX80 - KDX80-B3 Gear Change Mechanism
Kawasaki Motorcycle 1993 KX60 - KX60-B9 Gear Change Mechanism
Kawasaki Motorcycle 1992 KX60 - KX60-B8 Gear Change Mechanism
Kawasaki Motorcycle 1997 KX60 - KX60-B13 Gear Change Mechanism
Kawasaki Motorcycle 1998 KX60 - KX60-B14 Gear Change Mechanism
Kawasaki Motorcycle 1982 KDX80 - KDX80-B2 Gear Change Mechanism
Kawasaki Motorcycle 1982 KX80 - KX80-C2 GEAR CHANGE MECHANISM ('81 KX80-C1)
Kawasaki Motorcycle 1981 KX80 - KX80-C1 GEAR CHANGE MECHANISM ('81 KX80-C1)
Kawasaki Motorcycle 1982 KX80 - KX80-C2 GEAR CHANGE MECHANISM ('82 KX80-C2)
Kawasaki Motorcycle 1981 KX80 - KX80-C1 GEAR CHANGE MECHANISM ('82 KX80-C2)
Kawasaki Motorcycle 1984 KX80 - KX80-E2 GEAR CHANGE MECHANISM ('84 KX80-E2)
Kawasaki Motorcycle 1985 KX80 - KX80-E3 GEAR CHANGE MECHANISM ('84 KX80-E2)
Kawasaki Motorcycle 1985 KX80 - KX80-E3 GEAR CHANGE MECHANISM ('85 KX80-E3)
Kawasaki Motorcycle 1984 KX80 - KX80-E2 GEAR CHANGE MECHANISM ('85 KX80-E3)
JimmyB
- Been thanked: 14 times
JL you could also use part # 13242-1210,
https://en.impex-jp.com/catalogs/moto/k ... 84395.html
if you are looking for OEM
https://www.revzilla.com/oem/kawasaki/k ... id=1451603
or aftermarket ebay
https://www.ebay.ca/itm/173220451255
or aftermarket ebay
02 KDX220
