KIPS spring legth?
getherejune
KIPS spring legth?
HI all-well, my search found that the KIPS spring is not available (I saw it when i was doing the top end yesterday....must have went boing and is now somewhere in the shop. Dang it). Ive read i don't really need it, but figured since i have the ball bearing, i might as well. Read that a pen spring has been used, so will go that route. What i'm looking for is an approximate length or way to judge about how long to make it? (Pen spring i know is too long-Fits in the bolt nicely (assuming that is why the bolt is hollow) but approx how much spring should be coming out of the bolt? Thanks tons - (small parts don't mesh well with my lack of good vision unfortunately!)
- Molly's 70
- Has thanked: 2 times
- Been thanked: 3 times
Re: KIPS spring legth?
What timing. I just happen to be putting my spare cylinder together this morning.
That spring sits even with the top of the bolt. It's .335" long & .185" in diameter.
It is a little stronger than a ball point pen spring.
Hope this helps.
Hope this helps.
- Been thanked: 17 times
getherejune
Dang-i was thinking a pen spring would work as i read an old thread that Jeff Fredette had used pen springs as a substitute. Thanks tons M70. Will take a trip to my local Ace that has all kinds of random stuff like that and put a new battery in the digital caliper and see what i can find (Good info that it sits ON TOP of the bolt. i read some old threads where people said the spring was actually hiding inside the bolt, so thats why i thought it had to seat inside of it and not rest on top!)
- Molly's 70
The spring DOES rest inside the bolt. Its length is flush with the top.
getherejune
Ah! ok, gotcha M70-thanks so much for your help. So fits inside the bolt and stops flush with the bolt. Thats easier then-i can just take the bolt with me! Perfect timing, so thanks so much for your help :)
- Molly's 70
