I have recently fitted a Pro Circuit expansion pipe from a 1990 KX125 onto my KDX125.
It took a little bit of fab work but I managed to get it on there...
So now I know I have to rejet (which I have been doing) but I am running into strange issue. I was running a Big One / Fresco expansion but it was pretty dull to say the least and my goal is to try and make it as quick and reliable as possible.
I am running a Polini PWK30 flat slide carb and had it jetted pretty good with the Big One pipe, however now with the PC pipe I am getting misfires or stutters past 5/6k.
I have bumped the main jet up from a 130 to a 160 & checked the plug after any adjustments made and it still look very clean!
Is it possible that I am still lean even after bumping the main up that much?! The plug still seems VERY clean after a 5/6th gear pull.
Thanks guys!
