what carb do i have?
sandman
recently bought a 1996 kdx200. I want to start tuning my carb but am not sure which one I have. It is a Keikin PWK with V980 A1EQ stamped on it. I don't want to assume it is stock and after reading many posts on this site I see 35, 36, airstryker, quad vent. Thanks
- Been thanked: 19 times
Re: what carb do i have?
Well you can pretty easily tell if it's an air striker or quad vent, and you could measure it to determine the size. Start there.
- Has thanked: 191 times
Hi. Can you post a picture?
sandman
Did some research and found if it's got 2 vents it's not a quad or an air striker (not stryker). If it has fins on intake it is a striker. I have 2 vent lines. Next I need to determine exactly where to measure to verify if my carb is 35mm.
- Molly's 70
- Has thanked: 6 times
- Been thanked: 3 times
Measure the inside diameter of the small end of the carb.
- ss109
- Has thanked: 33 times
- Been thanked: 57 times
Stock there was only one carb available on the 200, a PWK 35. Good thing to verify, though.
