1984 kdx200
Re: 1984 kdx200
They have the same diameter at the exhaust port, but IIRC the pipe is shaped differently because on the 88 they changed the cylinder to accommodate the KIPS. You could probably cut and weld it if you are competent or know someone who is with a welder, but it likely won't be easy. You'd probably also need to relocate the mount brackets.
Re: 1984 kdx200
Dang I mean I have a welder myself but I’m not the best at it and don’t want to risk messing anything up thanks for the response I’m probably just gonna save a little money and get the dg expansion chamber
