Two Questions, well three.
wfopete
Post by wfopete »
First is there a link to common mods for 83-85 KDX's?
Second, What year KX upper triple clamps bolts onto those years bike?
and third, are there any aftermarket shocks available for 93-85 KDXs?
Thanks!
Suffer Fools, Gladly!
2006 300XC, 1980 YZ465, 1971 CZ250, 1973 Penton Jackpiner (2), 1970 Hodaka ACE 100, 1974 YZ250, 1973 CR250, 1985 XR350R, 1986 XR250R, 1974 TM400, 1975 TS400, 1974 Husky CR250, 2012 Yamaha Tenere', 1984 KDX200
Re: Two Questions, well three.
Fredette had a list of mods for various years. It is on the internet, not sure if he has the pre-89 mods on his site.
You can look up the parts diagrams on partzilla or elsewhere and click on the part number to see which other models had the same exact part number. I think the KX went from the 38 mm tubes to 43 mm in 1983?
Race Tech can. Works Performance use to make them.
wfopete
Post by wfopete »
Thanks, Jeff's stuff is pretty much limited to jetting for my year KDX. I don't think KX's and KDX's ever shared the same part numbers other than generic nuts and bolts. I believe the upper triples had different handlebar mounts and that's my interest. The KDX bar mounts are cast in and placed/angle too far back. I'm looking for a more forward conventional style mount. It's been about 40 years since I played with KDX's so I need to re-school myself. Thanks again.
I understand you on the bar mounts. The 1989 - 1992 is the same way (and part number) as the 1987 KX125.
The trick is going to be to get someone to accurately measure the offset and spacing to compare to a stock clamp.
Check out some of the KDX250 / KDX 400/420/450 clamps. 1982 KDX250 and KDX450 had bolt bar mounts.
