Front Spring Rate Question
stnd
Post by stnd »
Hi,
I have an '02 KDX220 with an '01 KX125 front end. I am 220lb without gear and am wondering what spring rates I should be running in the front. Originally when I did the swap I used Race Tech's website to calculate based on my riding for a 2001 KX125 and got a number which was close to the .41 springs that are in the forks.
After reading some threads on here people were mentioning heavier springs at my weight and now I think I should have calculated using a heavier bike on the Race Tech website.
Using a KX250 the spring rate comes up at 4.3 or 4.5 depending on Novice or Intermediate Trail/Enduro.
My shock spring is 5.4
Can anyone confirm whether .41 in the front is too little for my weight?
Has thanked: 71 times
Been thanked: 20 times
Re: Front Spring Rate Question
Go check your rate on a YZ250X, which is 0.44 stock and weighs about 218?? or so, which is 15 pounds less roughly.
You are not riding a 2001 KX125, so no need to check that.
Has thanked: 14 times
Been thanked: 22 times
I run spring rates at what it would be for a normal KDX for my weight and it always works out well for me. I'm 140lbs without gear and run .38 up front and 4.8 rear.
stnd
Post by stnd »
Thanks for the suggestions, I did end up emailing Racetech today to ask about the same thing, and they told me to look up spring rates for the bike i'm riding and buy that spring rate for the forks I'm running. So looks like i am ok with .41.
Thanks again.
0.41 is not right for you unless you are following the grandkids around.
I agree with KDXgarage. That spring recommendation is way too light.
When I was younger, and was a bit more aggressive rider, I ran .41's on my KDX with KX125 forks. Also, my buddy runs .40's and he's 170 pounds and is the same speed (a mid pack B racer) like me.
stnd
Post by stnd »
Thanks, that's exactly what I've been reading on this site, but I got that answer from Racetech.
I am probably beginner more than novice, and this is my first dirt bike so I have no frame of reference on how front should feel. Feels nice to me because all I had before was stock KDX forks which felt squishy.
Modifiers: (2002 KDX220)
Riding Type: Trail (single track)
Skill Level: Novice/C Class
Stiffness Preference: Standard Stiffness
Age: 30-44 Years Old
Height: Standard Rider Height
Gas Tank: Standard Gas Tank
Lowering: Not Lowered
Rider Weight: 220
FRONT FORK SPRINGS
Recommended Front Spring Rate: 0.41 kg/mm (Use closest available)
"The best you've ridden is the best you know."
- Paul Thede
Paul Thede is the founder and head of Race Tech. This is a situation in which his words apply well.
If those forks are not valved for your skill / terrain / weight, etc., then putting the correct springs in them is going to make it feel worse.
If you have stock MX valving, then you currently have a poor mismatch of wrong springs and wrong valving. Both are masking the other.
A fair amount of folks on here have two or three problems, not just one. Throwing the correct rate springs in there rips the Band-Aid off the other problem(s). :grin:
At the same time, I do actually see that many are not in a rush to throw hundreds of dollars into 20 year old forks on a xx year old dirt bike they just ride for fun. I apologize to everyone for seeming like I don't ever see it from that side. :mrgreen: If one is racing, then I am indeed saying to dump the money. :busted:
stnd
Post by stnd »
Hey thanks for that. I agree. This was my first step to addressing both the issues (Spring rate, and valving). Right now i ride with the compression 16 clicks out.
rungrandpa
Country: U.S.A.
Post by rungrandpa »
Perfect spring rate for me for fast desert is .46. Perfect for hopping around on tricky trails is .42 I leave them at .44.
Everything is a compromise it seems.
Goofaroo
Post by Goofaroo »
What is it that you don’t like about the forks that you have now? Did you try servicing the stock forks before you bolted a motocross fork onto your off road bike?
